Ext oil cooler
Old Apr 13, 2008 | 03:07 PM
spiritwarrior's Avatar
spiritwarrior
Default Ext oil cooler
Thinking about adding one of these to my 08 Street Bob. Seoul can hit over 100 on a hot summer day, and sometimes you can idle in traffic a long time on your way out of the city. So far in the spring seems like no problem. Oil cooler is almost $300 from HD. Do you think it is worth it? Or once my break-in is done just change to synthetic and let it gl?
Thanks.
Old Apr 13, 2008 | 03:24 PM
hk_shooter's Avatar
hk_shooter
Default RE: Ext oil cooler
A cooler is a good idea, just remember it only works while you're moving.
It won't help you when at a idle.
Old Apr 13, 2008 | 03:25 PM
bikerdog134's Avatar
bikerdog134
some of the texans should be able to help you out on this one
Old Apr 14, 2008 | 03:37 PM
spiritwarrior
Thanks. I have learned a few things, and that also some folks have misconceptions. Even when you are not moving an external oil cooler provides some relief as the oil is still being piped out of the engine into a cooler that is a leat 10-20 degrees cooler than the internal engine temps. I may rig a small electric fan connected to a sensor and have to blow on the oil cooler when the oil line hits 260f or so.
Thanks.
Mike N.
Old Apr 14, 2008 | 03:40 PM
Herr Monk's Avatar
Herr Monk
...you need a radiator
Old Apr 14, 2008 | 03:51 PM
Punty's Avatar
Punty
ORIGINAL: Herr Monk
No its for a Harley
[sm=joke.gif]
Old Apr 14, 2008 | 03:52 PM
the metal's Avatar
the metal
based on the weather there i would say it's a good idea- in phoenix here and i got one on mine
Old Apr 14, 2008 | 04:02 PM
Merlin's Avatar
Merlin
I was having BIG problems with overheating. Put on the super Premium oil cooler. Problems gone.
I can sit in the same traffic in the same 95 degree heat and I don't get the overheating problems I had.
Works for me!
Old Apr 15, 2008 | 08:48 AM
hk_shooter's Avatar
hk_shooter
ORIGINAL: spiritwarrior
Thanks.
Mike N.
Not sure why I have the misconceptions.
The only thing about thermo-dynamics I know is that the more magnets you have on your refrigerator, the colder it keeps the beer.
Could you please explain?
I' m always willing to learn.
How is theoil cooler going to remain 10-20 degrees cooler, short of having air going thru it?
If the oil coming from the crankcase is at say 200 degrees, goes into a cooler, after a very short while the cooler is going to get at or very near the same temperature (200 degrees), other than a slight radiant heat give off much like a heat sink in electronics.
And as a aside,why does the electric fan on the newer cages come onwhenstuck in traffic(not moving).
Heck, they even come on after the engine is shut off, sometimes.
Thank You
Old Apr 15, 2008 | 09:05 AM
atlasfields's Avatar
atlasfields
I put a Jagg on my Dyna.
