Front-End Clunk Fixed
Old Apr 17, 2008 | 06:51 PM
jmpancoast's Avatar
jmpancoast
Default RE: Front-End Clunk Fixed
Sorry this isn't a concrete answer to your question, but...
I would think that if you did the fall away test as described in the manual and your front end performs with the specs given, you should not have the clunk. This is assuming your greased bearings, races, and stem are in good shape.
Old Apr 17, 2008 | 07:08 PM
RKLeo's Avatar
RKLeo
ORIGINAL: up in minot
So is doing the fall away check the correct way totroubleshoot this "clunking" issue?
If you have not heard and felt it, you do not have it.
Mine happens when I hit a certain type of quick dip in the road.
It does not happen every time, but when it does you will know it.
There is a dip on the little road I work on. If I hit it at around 30mph or less, it happens every time. Any faster andit does not do it.
Old Apr 17, 2008 | 07:58 PM
up in minot's Avatar
up in minot
I do sometimes get a clunk. I can't tell where it's coming from though. The dealer said they're going to do a fall away check for me, under warranty. This is why I was asking. Even if they find nothing, atleast the fall away check portion of the 1k service I've been doing, on my own, gets done for free...
Old Apr 17, 2008 | 08:03 PM
RKLeo's Avatar
RKLeo
Make sure they know about the service bulletin, just in case
Old Apr 17, 2008 | 08:16 PM
up in minot
Yup! When I called to make the appointment, I made sure of that one. Thanks for the heads up though...
Hounds2
Dec 31, 2012 12:28 AM
Drakester
Jun 7, 2007 02:27 AM
BigGeorge
Sep 8, 2006 05:32 PM
dz672
Aug 19, 2006 01:12 PM
dz672
Aug 11, 2006 11:54 PM
