Change Trans Fluid
Old Apr 18, 2008 | 03:00 PM
bobncathy's Avatar
bobncathy
Stage I
Default Change Trans Fluid
Does anyone know how to change the primary and secondary trans fluid in my 2005 Dyna Super Glide Custom. I know how to change my oil but have never changed my trans fluid. Any help would greatly be appreciated...
Bob
Old Apr 18, 2008 | 03:46 PM
dyna07custom's Avatar
dyna07custom
Default RE: Change Trans Fluid
do you have a service manual if not your drain plug location is in your owners manual your trans fluid can be changed on the kick stand you primary bike needs to be level. You can accomplish this by putting a block under kick stand
1 Ride bike to warm oil up drain trans fluid and refill through dip stick hole
2 level bike drain primary then remove derby cover to refill to bottom of opening
your ownwers manual will give you capacities and oil recomendations if you do not want to use HD oil do a search on here ther are hundreds of posts on oil brands andspecs Take you time make sure you have the correct tools and it will be a snap
Old Apr 18, 2008 | 05:04 PM
cornishman's Avatar
cornishman
Perfectly said Dyna 07. KISS ( Keep It Short n, Simple)
kemiha
Feb 22, 2016 07:48 PM
Killswitch77
Jul 4, 2013 10:50 AM
rsnjr37
EVO
Mar 30, 2013 11:31 AM
wild_one
EVO
Sep 27, 2012 07:04 PM
85green
Aug 28, 2007 11:48 AM
