Expert advice?
Old Apr 19, 2008 | 12:47 PM
Gidz's Avatar
Gidz
Default Expert advice?
Hey guys. Just had the S&S a/c fitted and the Indie I use downloaded the codes for the V&H fuelpak. Bikes running smoother than it was and picks up a whole lot quicker, question I have is this: When I engage 1st and let out the clutch the bike cruises along at 10mph without any throttle. Is this normal? If anybody knows its going to be one of you guys.
Old Apr 19, 2008 | 12:59 PM
soup48's Avatar
soup48
Default RE: Expert advice?
I would call V&H to get a tech to tell what your problem is, that way he can tell you the problem. This way he can give you the right numbers to install in the fuelpak.
Old Apr 19, 2008 | 01:55 PM
Gidz's Avatar
Gidz
That was going to be my next step once I'd tried the question out here. Just wondered whether any of the guys with V&H fuelpaks could let me know about their experiences...
Old Apr 19, 2008 | 02:43 PM
kk6pg's Avatar
kk6pg
I cant help with the fuelpak, but I will tell you this:
I run a bone stock 08, and idling out in first gear is 10 mph. So its normal. The fuelpak shouldnt change your idle speed
Old Apr 19, 2008 | 03:11 PM
cornishman's Avatar
cornishman
As said the Fuel Pak should not affect the tickover.Is the idle speed is the same as before when the bike is up to running temperature.If it is then i,d assume things are ok. Daft question but you are up to temperature, as when cold the ecm sets a faster idle speed that does give similar symtoms.
AnimalRides
Aug 2, 2010 07:55 PM
Birdman2778
Apr 30, 2009 02:35 PM
railbird
Mar 5, 2008 01:38 PM
jpowell490
Feb 23, 2008 05:07 PM
blueson2s
Aug 3, 2006 10:32 PM
