Spark Plug wire
Old Apr 22, 2008 | 10:54 AM
BobbyD's Avatar
BobbyD
Default Spark Plug wire
One of my spark plug wires is beginning to discolor on the cap and there is only 280 miles on the bike. Anybody out there have any idea why? That bothers me a little since I'm concerned that we're talking about something that may burn up if there is a true problem.
Old Apr 22, 2008 | 11:18 AM
shimmon's Avatar
shimmon
Default RE: Spark Plug wire
I BET IT IS NOTHING TO WORRY ABOUT... WHAT COLOR ARE THEY TURNING. MINE WERE KIND OF WHITE-ISH, MAYBE FROM SOME WAX OR SUN, I DUNNO. BUT ANYWAY I JUST PUT A LITTLE LEATHER/VYNAL CLEANER ON THEM AND THEY WENT BACK TO BLACK. ALSO THERE IS A PRODUCT CALLED BACK TO BLACK THAT WOULD DO THE TRICK ALSO. JUST MAKE SURE IT IS SAFE FOR RUBBER!
Old Apr 22, 2008 | 11:54 AM
BobbyD's Avatar
BobbyD
Yeah, it's turning a whiteish green color and rubs right off just using a finger, really weird.
Old Apr 22, 2008 | 12:12 PM
shimmon's Avatar
shimmon
I WORK WITH HYDRAULICS ALL DAY AND SOME OF OUR O-RINGS COME IN A LITTLE WHITE-ISH... I WAS TOLD THIS IS SOMETHING THEY PUT ON THEM TO KEEP THEM FROM STICKING TOGETHER. I DONT KNOW IF IT IS THE SAME STUFF BUT... JUST MAY BE!
Old Apr 22, 2008 | 12:46 PM
kk6pg's Avatar
kk6pg
I dont think it's anything to get upset about.
the easiest way I know to turn the insulators and wires white is to introduce water or even faster, salt water to them while the motor is running.
You havent been giving your ride swimming lessons, have you?
Old Apr 22, 2008 | 01:07 PM
BobbyD's Avatar
BobbyD
Naw, I'm almost 200 miles from the nearest salt water (boy do I really miss it too, raised on the ocean front and loved it!). I guess I won't worry for now as long as my left leg doesn't catch fire. [sm=thanx.gif]
Old Apr 22, 2008 | 02:13 PM
dyna07custom's Avatar
dyna07custom
its just the effects of water on the wires even condensation will cause it wipe em down and ride it
Old Apr 25, 2008 | 01:46 PM
abate98's Avatar
abate98
Stage I
go and get 8mm wire set for your scoot ...better performance!!!
Old Apr 25, 2008 | 04:14 PM
Prodriverdon's Avatar
Prodriverdon
If you have spray silacone,put some on a cloth and do both wires.
Old Apr 25, 2008 | 04:45 PM
Razerman's Avatar
Razerman
What you may be seeing is a release spray that is used in the manufacturing,
It's almost like a waxy clear material that was not removed during assembly.
The release coating keeps parts from sticking in the mold when made and will
turn to a waxy powder coating where ever there is a sharp bend in the wire or
at the area of most vibes...rubber friendly cleaner will remove it..Hope this helped
big cahuna
Sep 22, 2018 05:39 PM
kwn36
Aug 19, 2013 02:19 PM
big kal
Aug 30, 2012 10:58 PM
zenwarrior
Jul 2, 2006 03:53 AM
69sport
Ironhead
Jun 29, 2006 02:22 AM
