HEAD LIGHT FLASHES WHEN BLINKER IS ON
Old Apr 22, 2008 | 04:58 PM
rroyster's Avatar
rroyster
Default HEAD LIGHT FLASHES WHEN BLINKER IS ON
I am changing my turn signals and brake lights. All of the lights except the head light have been removed from the bike. I cut the wires on each of the front turn signals and installed connectors on the ends. I have not cut into any other wires. When I connected the left front turn signal it flashed irradically, then stayed on steady and then flashed rapidly. The head light is not on anymore but flashes whenI turn the signals on. Any suggestions?????????
Old Apr 22, 2008 | 05:58 PM
hk_shooter's Avatar
hk_shooter
Default RE: HEAD LIGHT FLASHES WHEN BLINKER IS ON
I'd say the turn signal issue is because of a low amperage draw, similar to when you have a bulb burned out.
Proabaly won't blink correctly until you get all turn signals hooked up, or use a load equalizer.
As far as the headlight problem, sounds like some crossed wires.
But I didn't stay in a Holiday Inn Express.................
Old Apr 22, 2008 | 06:13 PM
HD7585's Avatar
HD7585
You have pinched a signal wire someware and it is shorting to ground
Old Apr 22, 2008 | 06:23 PM
coastrider's Avatar
coastrider
Sorry you're having problems. That is the main reason I have the dealer do all my wiring when I change lights. If you don't have a manual get one. It will pay for itself.
Ride Safe.
Old Apr 22, 2008 | 06:24 PM
deuceroadster's Avatar
deuceroadster
I just rewired a bunch of stuff myself. Same thing happened to me. In my case the bulb was blown and it caused all hell to break loose.
I'd hook everything up temporarily and see if the problem goes away.
Old Apr 22, 2008 | 06:58 PM
rroyster's Avatar
rroyster
Thanks for the help. I thought too that I had a short but I didn't cut into anything else. Of course its possible when pulling the harness back to get at the head light something came loose. The blown bulb is also a good possibility.Tonight I'll put everything together and see if that works.Thanks for the advice on the manual but I have one a refer to it often but you are right in that mine has paid for itself. As far as going to a dealer,I'll probably get screwed in labor cost to run down the problem. I'd rather screw myself; it's alot more fun.
Tpalmer1973
Electrical/Lighting/Alarm
Jul 23, 2018 10:09 AM
Kevin714
Mar 8, 2013 07:54 PM
Covenant
Jun 27, 2012 06:50 PM
Redmondp
Aug 16, 2011 07:37 AM
never enuff
Jan 7, 2008 05:39 PM
