SuperGlide speedo flip???
Old Apr 27, 2008 | 10:32 PM
simsjam's Avatar
simsjam
Default RE: SuperGlide speedo flip???
You can go with a digital speedo and mount. I installed the 03 and up Sportster Custom riser. Got the whole set up off Ebay from a wrecked one for a lot less that buying from the dealer. I made the whole change in one afternoon so it was plug and play. The stock handlebar wiring was a bit short for this setup but it did work. In the future when I have time I'll lengthen the wires and go internal on the bars. The bars are a bit higher than stock and my riding position improved. Once you go the Sportster way the only way to change ride height is with new bars- there is no way to change the riser. There is plenty of clearance with the stock tank but there is not enough room for any tank lifts.
Old Apr 27, 2008 | 10:57 PM
blueglide88's Avatar
blueglide88
ORIGINAL: simsjam
How did you wire it up? did you cut and splice the wires, or did you use a Sporty wire harness?
Old Apr 28, 2008 | 03:44 PM
hounddog's Avatar
hounddog
or this......http://i158.photobucket.com/albums/t...5/HPIM1386.jpg
expect i made the bracket and also relocated the lights to the dash with a custom billet alum. face to replace the crappy stock plastic one....
Old Apr 28, 2008 | 03:45 PM
hounddog's Avatar
hounddog
sorry....dumb a$$ link
<a href="http://s158.photobucket.com/albums/t...t=HPIM1386.jpg" target="_blank"><img src="http://i158.photobucket.com/albums/t...5/HPIM1386.jpg" border="0" alt="dyna dash an speedo"></a>
Old Apr 28, 2008 | 04:24 PM
Dawg Rider's Avatar
Dawg Rider
The Sporty Custom riser/gauge housinglooks good, and your stock gauge will fit in it. I think that's a good option. There's a forum member with a good how-to, but I can't think of his name right now. I was gonna do something similar, but I ended up chroming it when I changed bars and am happy with that, especially with the windshield on. But the FXD speedo mount really is better for riding (more visible), even though it ain't as pretty. And sometimes better for riding is more important than prettier (that's what she said).
Old Apr 28, 2008 | 06:48 PM
Twincam Dave's Avatar
Twincam Dave
ORIGINAL: JayFromPa
ORIGINAL: Twincam Dave
I thought the same thing too till I flipped it and the angle was all wrong. So I took it off and left it off, no speedo,no idiot lights just a bare clamp. Lost 5#'s by leaveing it off, besides I know how fast I'm going don't you? Dave...
What about the mileage? Or maybe you don't think thats nessacary?
Nope not necessary, I do 2 oil changes a year and service the trans and clutch every other time and figure its 5,000 on each change. What else do you need one for? Or do you need to impress someone on how little you ride?
Old Apr 28, 2008 | 07:01 PM
simsjam's Avatar
simsjam
It was all plug and play with the stock wiring but it was a bit tight. My setup came with the sporty wiring harness which had longer wires than the stock ones on my dyna but I did not feel like experimenting. The main connector to disconnect the stock wiring runs under the fuel tank and I did not feel likemessing with the tank. From the looks of it the sporty wiring would have worked. Otherwise with a little wiggling everything worked. The downside was the wires are meant to run down a channel between the risers so with the stock wiring I had to leave it hanging out the sides. Since the stock wiring is a bit tight and it is held with plastic connectors to the bars, you will need to detach them to get enough slack. Like I mentioned before I'll leave it that way until I make the wiring internal to the bars. The stock brake hose will work but you need to straighten out the metal connector to the master cylinder get a little slack. So far I have not done any cutting and splicing. The stock speedo fit with no problem. I like the position a lot better over stock. I wish this was a factory option but I guess they dont want the FX and XL lines to cross.
ORIGINAL: blueglide88
ORIGINAL: simsjam
Old Apr 29, 2008 | 06:50 AM
Dawg Rider's Avatar
Dawg Rider
I just remembered...simsjam-that's the guy! I knew it would come back to me.
Old Apr 29, 2008 | 08:33 AM
Righteous's Avatar
Righteous
This is definitely nota cheap solution. But, Drag Specialties has $800 mirrors with a digital tach, speedo, and indicator light built into the glass. They are really cool. You can get rid of the whole instrument cluster with this.
Old Apr 29, 2008 | 08:40 AM
DiabloBlanco's Avatar
DiabloBlanco
Jason Great lookin set up I want to do something simiar on my 05 FXDC. Just one question how did that add up to close to 2 G's?
hommes
Mar 24, 2016 08:23 PM
Roorat60
Mar 28, 2015 01:50 PM
jtj75
Stock Harley Take Offs
Feb 19, 2015 11:11 AM
doc_green35
Mar 30, 2014 10:30 AM
PaDutch
Sep 21, 2010 10:14 AM
