Throttle Holding Screw
Old Apr 28, 2008 | 03:36 PM
Shrug's Avatar
Shrug
Default Throttle Holding Screw
Does anyone know what is inside the switch housing above the throttle holding screw on the right bar? I recently installed LED mirrors and had the switch housing apart. When I reassembled, the screw will go all the way in and never engage the throttle tube end. The service manual only says there is an unattched part that can fall out if you're not careful. Apparently I wasn't careful. I re-opened the switch housing to look for something obvious, but with the throttle cables in place, I can't see squat under the throttle tube and it's a pain in the butt to reattach the top cable. I don't even know what part to order to replace it. I figure if there were a part misplaced and loose in there, the housings would not have fit back together and/or the throttle would be sticky.
I know here are plenty here who say to never use it, buy I ride 600+ miles a week and the screw with a Throttle Mate are a right-hand life saver.
Any insight appreciated.
Old Apr 28, 2008 | 03:47 PM
evansf_fde's Avatar
evansf_fde
Default RE: Throttle Holding Screw
There is a little curved plastic piece that creates the friction when you turn the screw in. About 1/2 inch less wide and 3/4 inch long (Approx)
Old Apr 28, 2008 | 03:49 PM
Shrug's Avatar
Shrug
Thanks, man. I wonder how I missed that!
Old Apr 28, 2008 | 06:37 PM
mud's Avatar
mud
scott, here is the part #56396-74A
I have one if you want it I'll mail it to you
Only about a buck and a half at the dealer.
Look around on the floor, You may find it.
mud
ORIGINAL: ktm_scott
dellagratti
Dec 17, 2013 06:08 AM
Razorback Rob
Sep 20, 2010 12:09 AM
AdrianVall
Dec 26, 2008 11:45 AM
yodal
General Topics/Tech Tips
Oct 7, 2005 07:27 PM
philly_night_train
Sep 27, 2005 10:09 AM
