PCIII help
Old May 1, 2008 | 08:05 PM
low_n_slow's Avatar
low_n_slow
Default PCIII help
Hi guy looking I'm looking for some help here is my setup.
2008 Fat Bob
V&H BSS
SE Air Filter
PCIII
I have had the bike to a certified tuner here locally 4 timeI have had my bike to him.
and I still have back firing on decel,and I think I and running a little lean, my plugs are white. just at the center. Is there anyone on here that is running a 07 or 08 Dyna with this set up?
If so could some email me or post up a map so I could at least do a compare between maps.
I could really use some help,
Thanks guys.
[IMG]local://upfiles/50688/FDBB6E829D224DBE839CA9A4D97E5650.jpg[/IMG]
Old May 1, 2008 | 09:16 PM
joe.1955's Avatar
joe.1955
Default RE: PCIII help
I am running the same setup on my '08 WG and it has been dyno tuned. The AFR is about 13.1:1, and set richer at lower RPMs.
I am at work until after midnight (Arizona), but can send you the map when I get home.
Old May 2, 2008 | 01:40 AM
SK8ROD's Avatar
SK8ROD
i got a map from Fuel Moto for short shots etc you can try, its richer than the one you have there, email me and i can send it you
pete
Old May 2, 2008 | 03:20 AM
joe.1955's Avatar
joe.1955
Here's my settings, front and rear cylinder.
[IMG]local://upfiles/47632/24161E22813949108425369BCF4579D7.jpg[/IMG]
Old May 2, 2008 | 06:47 AM
low_n_slow's Avatar
low_n_slow
Hey Joe
Sent you a email.
I appriciate you help this place has been driving me crazy, and its a Harley Shop
That is the best part of it all.
Old May 2, 2008 | 06:50 AM
freddy.dj's Avatar
freddy.dj
Hi, I think you can try to add somemore gasoline for the throttle at 0% 5% and 10%.
I have the opposite problem. No decel pops but no torque at low rpm... At high end it's a rocket but I need more torque at lower end.
My bike is not dynoed and has the following features:
MY06
8° injectors
Screaming Eagle A/C
2in1 race exhaust (completely open)
any suggestion?
(sorry for the post-stealing...)
stmpulr
Mar 2, 2010 09:01 PM
Molzy
Dec 19, 2009 08:22 AM
AdrianVall
Exhaust System Topics
Aug 29, 2008 12:02 PM
gapwl3
May 15, 2008 04:06 AM
Dsanchez
20
Nov 5, 2007 05:29 AM
