Pause in Carb
Old May 5, 2008 | 11:13 AM
Tuggin's Avatar
Tuggin
Default Pause in Carb
I just bought my first Harley...My 98 SG with 10,170 miles has pausein the carb when I am just cruisin along and accelerate, alsowhen I filled up the tank it backfired through the exhaust when I started it.Are the stock carbs any good? What can I do to improve the performance?
TOM
Old May 5, 2008 | 11:24 AM
SUPER01's Avatar
SUPER01
Default RE: Pause in Carb
Stock carbs are good unless you have big bore and other go fast items.
Sounds like it might be running a little rich, backfire out the exhaust w/carb means unburned excess gas.The pause, does it sound like the engine bogs then takes off? It maybe jetted so its running a bit rich.
Any independent shops near you that have a dyno you could run it on to check the air/fuel mixture? The one by me only charges by the hour for bikes w/carbs and it usually takes an hour.
Also check out the Engine/fuel/intake section of the forum.
https://www.hdforums.com/forumid_266/tt.htm
Let us know what you come up with.
Old May 5, 2008 | 11:35 AM
Tuggin's Avatar
Tuggin
No the engine does not bog when I take off. It idlesand runsout fine, except for the pause. The bike is totally stock except for an aftermarket air filter assembly.
2006ultra
EVO
Jun 13, 2014 04:03 PM
terrapin88
Apr 6, 2010 11:17 AM
ironsport83
Ironhead
15
Sep 4, 2009 08:44 PM
hufdvr
Dec 14, 2007 07:53 PM
f6noob
Exhaust System Topics
Apr 20, 2007 02:32 AM
