progressive 412 questions
Old May 9, 2008 | 09:43 AM
steelcowboy's Avatar
steelcowboy
Default progressive 412 questions
Can anyone help me pick the right height for my new progressives. i'm gonna be running the metz 200 on back and riding 2 up. I didn't really wanna go lower but it seems to be hard to find a set of black progressives that aren't. Also whats a good price for them I found them fpr 195 on ebay. But again they are the 11's
Old May 9, 2008 | 09:47 AM
Shrug's Avatar
Shrug
Default RE: progressive 412 questions
I'm running 11" with an 18" rim and a 180x55. The 200 is the same overall diameter and would fit under my WG fender. I rode 1000+ miles two-up with this set up.
Old May 9, 2008 | 09:49 AM
trampsinger's Avatar
trampsinger
I have 11's also. They're pretty rough solo but great two up. Huge handling difference though!!!
Old May 9, 2008 | 11:58 AM
misterkidgo's Avatar
misterkidgo
Can you guys indicate whether you are running the Heavy Duty versions or not.
I'm also interested in the 11" 412s, majority solo @165 lbs, but every so often with the little lady @125 lbs. I don't think I need the Heavy Duty's.
Will anyone confirm? And how does the ride quality differ anyhow? Thanks.
Old May 9, 2008 | 02:57 PM
lolife's Avatar
lolife
Im not running the heavy duty......... . also running 180.... . no probs.............. . . . .........
Old May 9, 2008 | 03:08 PM
2007fxdc's Avatar
2007fxdc
ORIGINAL: misterkidgo
Progressive recommends HD's if you carry over 200 lbs most of the time. Doesn't sound like you want HD's. If you do add more weight, just click up the preload a notch or two. I believe the loaded HD's ride similar to the non-HD's but are a bit stiffer ride when not loaded over 200 lbs similar to what trampsinger is saying. On the other hand, if you are stuffing the fender and don't want to chance tire contact, you could go with the HD's since you are looking at 11" models and just keep them at the lowest preload setting. When I first installed mine, I put them on the lowest setting and bottomed out on my 12"ers so they aren't terribly stiff, even though I weight 240. I clicked them up to 2 and they are great 1 up or 2 up now.
Old May 9, 2008 | 03:13 PM
07bobber's Avatar
07bobber
I GOTS THE 11 HD PROGRESSIVES......AND THEY ARE DEF. ROUGH SOLO BUT GOOD 2 UP.........NOT SURE IF IM GONNA KEEP EM OR NOT THOUGH......
Old May 9, 2008 | 03:46 PM
Cornhusker's Avatar
Cornhusker
I love my 11" Progressives. I only weigh 160lbs so they're set on the softest setting and I don't find them rough riding at all during routine city or hiway riding. Surprise bumps hit a little harder than theOEM 12"ers, but I don't hit them that frequently.
Old May 9, 2008 | 07:26 PM
Chipstah's Avatar
Chipstah
I have the black 11" Heavy Duties and am 185 lbs. and never ride 2 up -- got the HDs on purpose for the improved handling and didn't care if they were stiff or firm - in fact prefer it, and if I ever want to go 2 up, I can do it easily by changing preload settings as needed. Absolutely no regrets and no worries with bottoming out, but I wouldn't recommend this to just anyone. However, if you like the hunkered down cornering of a sports car and aren't looking for a cushy ride then these are what I'd recommend, and no noticeable difference on the highway, just secondary roads where you feel every bump but handle the twisty bits like nothing else.
Old May 9, 2008 | 11:14 PM
XKROME's Avatar
XKROME
ORIGINAL: steelcowboy
here's a site if you don't want to go lower
http://www.onestopmoto.com/product_p/hdps-412hd-007.htm
a little more $ but more selection. i just ordered the stock length for my SG cuz i didn't want to scrape pegs any more than i already do. should be here next week.
patrickd
Jul 5, 2012 10:00 AM
genejohnson
Apr 26, 2011 09:23 AM
mea3pk
Jun 4, 2008 06:27 PM
Roofuss96
Sep 7, 2007 04:59 PM
SERB
Feb 21, 2005 12:16 AM
