anyone used these
Old May 13, 2008 | 04:05 PM
wiegs's Avatar
wiegs
Default anyone used these
Looking to keep my midglide front end but get a little more rake. what do you think of these with 3 degrees rake? I am assuming this will do the same as wide glide trees. The rake will be increased 1.5 degrees. True?
http://www.dragspecialties.com/fatbook/11/598/5929457
Old May 13, 2008 | 05:09 PM
Righteous's Avatar
Righteous
Default RE: anyone used these
I wondered about that too. The HD specs for my lowrider says the rake steering head is 29 degrees. I assume that means the angle of thesteering head on the frame. The HD website says it has a "49mm front forks with 30.5 degree rake angle". I guess that means the rake of the forks. So, if I understand this correctly, the trees must have 1.5 degrees of rake.
So, The 3 degree triple trees in the Drag Specialties catalog will add another 1.5 degrees.
Is that how you see it? Or, did I get this all Fd up as usual?
Finally, if all of that is true, how will it ride to have a total of 3 degrees of rake in the trees? Is the trail going to be stable/safe?
Old May 13, 2008 | 09:56 PM
wiegs's Avatar
wiegs
I think it will ride/handle the same as doing a wide glide conversion.
sothai
Dec 3, 2012 05:29 AM
cwsharp
Nov 19, 2012 09:56 PM
Goodsy
Jul 14, 2012 07:52 PM
JCK
Feb 20, 2010 12:25 PM
HDDYNA
Feb 18, 2009 04:26 PM
