Anyone with Kury forwards question
Old May 21, 2008 | 02:28 PM
ShoreRider's Avatar
ShoreRider
Default RE: Anyone with Kury forwards question
Have had mine on for 8 months and couldn't be happier. And never noticed any excessive side-to-side play.
Old May 21, 2008 | 02:32 PM
toro27's Avatar
toro27
JerseyDevil, had a question about doing it my self, would i have to take off the inner primary also? I have a 2007 FXD My forwards are from HD.
thanks
R
Old May 23, 2008 | 01:20 AM
Funkhousert's Avatar
Funkhousert
ORIGINAL: toro27
thanks
R
Hello Toro27. Do a search for forward control install and you will find SEVERAL posts about the inner primary. I did not remove the inner primary only the outer and replaced it with a different outer that does not have the hole. Depending on the kit you buy, it may come with a bracket to attach to the original shift linkage and a chrome cap to cover the existing spline.
I personally just pushed the existing mid control shaft back and wedged it behind the crank case bolt as others here have done and that is where I found the information about doing that.
Some have also just took a hacksaw blade and went underneath the bike and cut the shaft and removed it completely. Its all up to you. Here are a few links that I searched for you just now. Its really your decision on whether or not to remove the shaft.
https://www.hdforums.com/m_1636075/tm.htm
https://www.hdforums.com/m_2355373/tm.htm
https://www.hdforums.com/m_1828627/tm.htm
larsfum
EVO
Feb 28, 2013 04:43 PM
kh24
Jul 10, 2011 03:49 PM
moto monkee
Oct 2, 2010 10:16 AM
thone
Aug 17, 2010 07:34 PM
Top
Feb 18, 2008 05:31 PM
