new pipes question on install order
Old May 20, 2008 | 11:26 PM
urdollar's Avatar
urdollar
Default new pipes question on install order
I have an 05 superglide and have bought shortshots, big sucker and a fuelmoto pcIII.
Does it matter in what order they are installed as long as you don't turn on the bike. I was going to do the hard install first, (shortshots) and end with the pcIII. Just curious if it matters. Because of work it will be about a week before I can install them so I have some time to plan it out.
Thanks
urdollar
Old May 20, 2008 | 11:32 PM
OhioSkully's Avatar
OhioSkully
Default RE: new pipes question on install order
It does not matter what order as long as you do like you said and in all reality if you turn it on your not going to hurt it. It the long term effects of riding it if its to rich or to lean that will do the damage.
The pipes are pretty easy, the big sucker is pretty easy. The PCIII is easy except the getting the dam thing to fit in the tiny area it needs to go it it will take you the longest and the pipes and the ac is the easiest.
Old May 21, 2008 | 05:44 AM
LeadSlinger0311's Avatar
LeadSlinger0311
your fine in what ever order you decide man .
I have the Short shots staggerd and Big sucker .
Big sucker all of 10 min to install
pipes about 45 min to and hour
and had a fuel pak but that is off now.
good luck man .
you should really like the parts you bought
Slinger
zZeduardoZz
Oct 8, 2014 11:09 PM
AdrianVall
Dec 24, 2007 01:06 PM
FXSTBO8
Exhaust System Topics
Oct 3, 2007 01:35 PM
Ezy_43
Aug 14, 2007 01:06 PM
ScooterGuitar
May 22, 2006 10:24 PM
