FAT Bob Slip-ons installed: Beware
Old May 24, 2008 | 07:53 AM
fsnco's Avatar
fsnco
Default FAT Bob Slip-ons installed: Beware
Finally installed 2' Rush Slip-ons. Its night and day difference on the stock Fat Bob. It was an easy MOD but for all of you out there thinking of doing this beware: the specs ask for 60 ft. lbs of torque, i had the torque wrench set at 60.5 aqnd it broke the muffler clamp bolt.... got that fixed and then sheared off the bolt that holds the slipons to the frame midway down the pipe. a 20 minute mod ended up being a 3 day affair...
Old May 24, 2008 | 08:45 AM
SilentWarrior's Avatar
SilentWarrior
Default RE: FAT Bob Slip-ons installed: Beware
I did mine without a torque wrench and it worked out fine. Not saying you shouldnt use one..got lucky I guess. I have the same pipes. The 2 inch Rushare good for those people that want louderdeeper pipes but not to loud. Sorry to hear about your troubles getting them on, sounds like all worked out in the end.
Old May 24, 2008 | 08:54 AM
ta2ed's Avatar
ta2ed
Dont feel bad man!I did the same thing. I chalked it up as a miscalibrated torque wrench and dropped it to 55lbs. I may be wrong butI think the specs are 50-60 lbs. So I definately would agree with you that they snap pretty easy. (I thinkthey are designed to) So for all of those putting on the slip ons stay in the lower part of the torque range and save yourself 9 bucks a clamp.
Old May 24, 2008 | 10:04 AM
fsnco's Avatar
fsnco
it worked out ok and like the pipes. Do have a question for you guys, I noticed you can easily take out the baffles of the pipes, has anyone ever done it and if so can you put them back in or is that it? Maybe a dumb question but just not sure.
Old May 24, 2008 | 12:54 PM
ta2ed's Avatar
ta2ed
I may be wrong but rush slip ons may have different baffles available to go louder or less loud. I'd look on rush's site to see if you can buy different baffles for em. If you can you've found your answer on why they can come out.I wouldnt run it with no baffles your bike. Ifit's stock it willprobably beway too lean. Just my opinion, but like and a-hole everyones got one.
Old May 24, 2008 | 02:31 PM
Lineskinner's Avatar
Lineskinner
IGOT MY 1.75'S YESTERDAY AND INSTALLED THEM TODAY THEY SOUND AWESOME. I DIDN'T TORQUE, JUST TIGHTEN THE CRAP OUT OF THEM. QUICK MOD FOR GREAT SOUND AT A GREAT PRICE. ENJOY.........
Old May 24, 2008 | 04:42 PM
RAWHIDE07's Avatar
RAWHIDE07
I've torqued countless thousands of fasteners(aerospace/aircraft) so I know that a good "feel" for what you are doing is more important than torque numbers.Any torque wrench used in my industry are calibrated on a regular basis.
tmac00333
Mar 8, 2018 11:23 PM
BCB846
Exhaust System Topics
Mar 11, 2015 03:57 PM
Cory81
Apr 11, 2014 06:08 PM
Seant01
Aug 9, 2009 09:17 PM
Bat
13
Apr 23, 2008 10:50 PM
