PCIII Users?
Old May 26, 2008 | 10:54 PM
beaverretriever's Avatar
beaverretriever
Default PCIII Users?
When installing the PCIII, does it matter if your stock ECM has the dealer / se stage 1 download already? Was not sure if this effects anything with the PC?
Old May 26, 2008 | 11:17 PM
joe.1955's Avatar
joe.1955
Default RE: PCIII Users?
I installed one for a friend that already had the download, using a canned map from the website.
Ran ok once we zeroed the closed throttle position.
The maps are very general, you might try different maps to get the best performance.
If you order / ordered from Fuel Moto, they might have a map for your configuration with the download.
The other option is to have the bike dyno tuned for optimum performance and AFR.
Old May 26, 2008 | 11:19 PM
Bluesssman's Avatar
Bluesssman
Not a problem, you will just need to find a map with your specs. Be sure to get the closed throttle set up right!
Old May 27, 2008 | 01:43 AM
SC-Longhair's Avatar
SC-Longhair
Since laying out close to $1100 at once isn't in my budget, I was going to buy the PCIII first. Does adding that, with the stock map add any power to the motor?
Old May 27, 2008 | 01:54 AM
devobail's Avatar
devobail
ORIGINAL: sclonghairbadboy
I bought my PCIII before the pipes and air cleaner. Installed it and yes it ran alot better! Cooler and with more power. Run it like that for 9 months before installing Rinehart TD's and AN Big Sucker.
Old May 27, 2008 | 02:28 AM
SC-Longhair
I kind of figured it would but wasn't sure...this is my first rodeo with fuel injection.
Old May 27, 2008 | 05:22 AM
jsbridgew's Avatar
jsbridgew
I was told by a reputable builder in canada that the stage 1 download is an advantage when tuning with a pc3 because it will allow you access to timing tables that will be within range for calibration.
txphatboy
Exhaust System Topics
Dec 10, 2012 09:16 PM
Taterdog
May 21, 2009 06:49 AM
128auto
Aug 19, 2008 01:11 PM
salty01
May 30, 2008 03:24 PM
redhwk44
Sep 12, 2006 01:40 AM
