PCIII First Ride
Old Jun 1, 2008 | 09:39 PM
beaverretriever's Avatar
beaverretriever
Default PCIII First Ride
Did the install today on my 08 FXDC.PCIII using the Dynojet Thunderheader SE filter Map. After using the dealer Stage 1 download for the last 2 months, I can honeslty say WOW what a difference. The decel popping is gone and the mid range power is night and day better. Bike runs much cooler. That popping was really getting to me as well as the hot motor.
The install was not bad at all. I read allot of info on here regarding theinstall/mounting etc. Saved allot of 4 letter words. I was done on about an hour including setting the throttle zero. So far i am real pleased.
Old Jun 2, 2008 | 01:52 AM
SK8ROD's Avatar
SK8ROD
Default RE: PCIII First Ride
yeah the PCIII is an excellent piece of hardware,, have you tried out the accelerator pump?
Old Jun 2, 2008 | 11:18 AM
beaverretriever
Accelarator pump? Is this one of the parameters you can change within the PCIII software?
The only thing I have done is download the map and set the throttle zero. Now that its done I will start learning the other settings.
Old Jun 2, 2008 | 11:29 AM
ehretja's Avatar
ehretja
Beaver, you'll need to download the software if it didnt come with your set up. I just downloaded mine the other day and got it enabled. When you have the PCIII hooked up to the computer and without the PCIII software up and running just run the accelerator pump software. It'll allow you to adjust it and it helps with throttle response.
Old Jun 2, 2008 | 02:56 PM
beaverretriever
Ehretja,
Where did you download this software from? I only downloaded what was on the CD that comes with the PC. Would this be under "tools" in the PC software?
Old Jun 2, 2008 | 03:07 PM
ehretja's Avatar
ehretja
http://www.powercommander.com/powerc...downloads.aspx
you can get to it on the power commander web site..... under support .....downloads....
bdbaggr
Oct 22, 2010 10:08 AM
neilgehrke
Apr 23, 2010 08:27 AM
128auto
Aug 19, 2008 01:11 PM
beaverretriever
May 27, 2008 05:22 AM
chapdaddy
Jun 9, 2007 11:37 PM
