Derby Cover
Old Jun 4, 2008 | 12:43 PM
Luther OBanion's Avatar
Luther OBanion
Default Derby Cover
Question, I am going to change my derby cover off my 06 Bob. Need to know if I will need to change the gasket also. Rode numerous years before kids came along, now been back at it for a couple of years. Bikes have changed a lot in 30 years. The stock one is just a piece of stamped out chrome or stainless steel. Looking to upgrade it. Thinking about a Harley Flame (gold & silver) style. Need good advise in the mechanics of how to do this. Do not have a manual. Any good advise is welcome.
Old Jun 4, 2008 | 12:53 PM
Gaffy52's Avatar
Gaffy52
Default RE: Derby Cover
I've always been a bit of a belt and braces guy on this one - if it has a gasket andit getsdisturbedI would always replace it with a new one. Done this ever since I was kid wrenching my own engines and the like. Doesn't cost may more pennies and myOld Manalways said it was good practice.
Old Jun 4, 2008 | 12:56 PM
JRK5892's Avatar
JRK5892
replace it or make your own... i have a ton of gasket sheets, so i just cut new gaskets anytime in do my fluids
Hounds2's Avatar
Hounds2
the gasket costs about 8 bucks. i keep one on hand if i need it. usually if you are carefull you can reuse at least once. you will know if you dont get away with it...then change it..
good luck
scott
Old Jun 4, 2008 | 01:24 PM
cjhumphrey's Avatar
cjhumphrey
If you replace the factory cover with an aftermarket one, then you're going to need to get a "sheet" style gasket. The factory "O-ring" style won't work on most aftermarket covers.
Old Jun 4, 2008 | 01:39 PM
grape ape's Avatar
grape ape
ORIGINAL: cjhumphrey
[sm=icon_ladiesman.gif] They're just a few bucks at any dealership.
Old Jun 4, 2008 | 01:43 PM
first dyna 07's Avatar
first dyna 07
I took my cover and gotit engraved very custom . It cost me 25.00 and it is one of a kind .
Old Jun 4, 2008 | 03:29 PM
FrenchXD's Avatar
FrenchXD
I've changed or removed mine 4 times, using HD covers, I never replaced the o-ring type seal, even if I got a new flat sheet type one.
There is no pressure inside the primary that will push the oil out. I always clean the parts before reassembly and torque to spec.
Luc
Old Jun 4, 2008 | 04:13 PM
BlockHead96's Avatar
BlockHead96
ORIGINAL: first dyna 07
PIC's??
Old Jun 4, 2008 | 07:44 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
&nbsp\\;
&nbsp\\;If you have the miles on the bike why not change the fluidwhile the cover is off? Be very careful removing the Torx fasteners on the derby cover, especially if it's the first time they are coming out.
