Please help quick! AKA Glowing Pipes
Old Jun 7, 2008 | 02:53 PM
96 Wide Glide's Avatar
96 Wide Glide
Default RE: Please help quick! AKA Glowing Pipes
There's a saying in the outboard motor world that goes, " A motor runs it's very best, right before it blows up!" .
&nbsp\\;
Good luck... Ben.
Old Jun 7, 2008 | 03:21 PM
Daehawc's Avatar
Daehawc
nice quote ben, kinda makes me uneasy though.
JRK: Besides the shattered pipes what other damage did he have to his bike? The only thing I'm worried about is my motor. I will be PCSing from Florida in about a week and a half/ two weeks so all my money is going to the move. If I have enough money left over from that then I'm going to get the TMAX auto tuner to make sure the bike is getting the fuel it needs. From now until then I just don't want to burn out my engine but I obviously still want to ride. I also want to put on new pipes but my worry is that if the thicker-walled aftermarket pipes do not glow is that just hiding my condition or is it "fixed."
Old Jun 7, 2008 | 08:46 PM
dhoward's Avatar
dhoward
Pipes "shatter"? Gimme a break.
Don't keep feedin' the dealer money to "try" stuff. They're telling you not to look ay it. Take their advice.
Listen to Steve.
It's an 08. It's under warranty
Old Jun 7, 2008 | 09:14 PM
maddghost's Avatar
maddghost
ORIGINAL: dhoward
Listen to Steve.
&nbsp\\;
It,s under warrenty if he brings it in with original parts.bring it in with V&amp\\;H pipes and arlen ness&nbsp\\; BS and they will tell him it,s his own fault!&nbsp\\;
&nbsp\\;
I Think!
&nbsp\\;
Any way if I run my engine in a closed space for 2 or three minutes they get red hot , but never when Im riding around with it.
Old Jun 7, 2008 | 11:41 PM
06dynablack's Avatar
06dynablack
ORIGINAL: dhoward
Listen to Steve.
+1
Old Jun 8, 2008 | 01:51 AM
labfreak's Avatar
labfreak
Got off the freeway, let her idle awhile, put the infrared thermo right at the header pipes where they exit the heads and got 550 degrees, man, that is the hottest spot and 550 is not glowing, somethin wrong when the pipes are glowing IMO.
Old Jun 8, 2008 | 03:24 PM
Daehawc's Avatar
Daehawc
Short version of my long post that wouldnt post.
Labfreak, your running those pythons in the pic right?
Old Jun 8, 2008 | 03:26 PM
Daehawc's Avatar
Daehawc
I got&nbsp\\;digital thermo to check, highest I saw after 5 min idling was 450, usually seeing around 350.
Old Jun 8, 2008 | 03:34 PM
Daehawc's Avatar
Daehawc
if we all donate a dollar can we fix the forum?
Old Jun 9, 2008 | 02:23 AM
LownBlue's Avatar
LownBlue
If all is running well and you are under warranty. Do not give $550 plus dollars to the stealer
for a Super Tuner. Save your dough and get the Thundermax autotune you mentioned. My bike
has never run better or cooler since I did the install on mine.
