Alarm key fob
Factory default is 7-7-7-7-7 afaik, though whoever owned my bike before must have set their own and didn't write it in manual [:@]
You need the functioning key fob with you when you do this.
1. Turn ignition key: ignition-off-ignition-off-ignition
2. Press left turn signal switch 3 times.
3. Press right turn signal switch 1 time.
4. Set the first number of your PIN by pressing the left turn signal switch however many times you want the first number of your PIN to be (if the first number of your PIN is 3, you would press the left turn signal switch 3 times).
5. Press the right turn signal switch one time to move to the second number of your PIN.
6. Enter the second number of the PIN using your left turn signal switch as in step 4.
7. Keep repeating the process until you have entered all 5 numbers.
8. Turn ignition off.
It helps if you have your display set to odometer, because the numbers you set will show up on the odometer. That way, you can be sure you're setting the PIN number you think you are.
He tried it this morning \\;at home with spare fob and up she sparked
But if you read your owners manual you can easy control what code it is and then change it if you want.
Will have another look for that section, also occurred to me that maybe a code had never been set in the first place.
According to my dealer there is no factory default.
To set/change the PIN (at least on a Fat Bob)
Thanks Evil Stepdad, keep it jingling. \\; Bob
[hr]
https://www.hdforums.com/m_1629276/tm.htm
Thanks to hAkron
My default came up on odometer as 1-1-1-1-1
Input my own code and disabled alarm using indicators
