I've had a problem at the Triumph dealer at Vauxhall.
Apparently all the radiation from the comms equipment in the MI6 building interferes with the bike alarms.
ORIGINAL: domenicp7
Ignition On
Press both turn Signals at the same (quickly after ing is turned on )
Odometer shows five slashes\\\\\\\\
Using the left \\;\\\\\\;\\\\\\\\\\\\\\;turn signal \\;\\\\\\;\\\\\\\\\\\\\\;for imput press once is a 1 twice is 2 you get it.
Using the right to verify if its a one press the \\;\\\\\\;\\\\\\\\\\\\\\;right turnsignal \\;\\\\\\;\\\\\\\\\\\\\\;once the first slash will be a one \\;\\\\\\;\\\\\\\\\\\\\\;and so on till you imput the 5 digit code. \\;\\\\\\;\\\\\\\\\\\\\\;
I now have a piece of mind. \\;\\\\\\;\\\\\\\\\\\\\\;
Remember to push your key \\;in a bit further \\;once ignition is \\;on \\;and turn key one notch further round to "acc" setting.
Also, when re-setting pin-code you have to put "run" switch to off.
On my 07 Heritage the run switch had to be on. The battery number for 07 is CR 2032. 3v. Im going to pick up a pair and put them in the saddlebag just in case.
happen to me three times after filling my bike...it would not start,,,,
i just push my bike like three feet and it stated right up...i think their are
weird waves that play tricks on the fob AT THE GAS STATION..
