longer front fender
Old Mar 3, 2006 | 04:31 PM
sporty2003's Avatar
sporty2003
Default longer front fender
i have been looking for a longer front fender for my 05 super glide and i have seen them made of fiber glass and some metal i want to stay with the thin just longer in the back any body got any ideals .
Old Mar 3, 2006 | 06:02 PM
Silverglide's Avatar
Silverglide
Default RE: longer front fender
I put a mud flap on mine, right out of the Harley book. A little pricy like everything in the Harley book, but looks pretty good I think!!!!
Old Mar 3, 2006 | 10:20 PM
DGlide04's Avatar
DGlide04
If you don't like the look of the shorter stock fender you can always go back to a more traditional (larger) Sportster or FX type fender. They're pretty interchangeable, but I don't know if they're available for the 2006 models. Just a thought.
Old Mar 4, 2006 | 02:48 AM
veniculum's Avatar
veniculum
I have the HD chrome front fender extension on my Wide Glide. I like it...just an idea
Todd
Old Mar 4, 2006 | 02:58 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
You might try here............http://www.russwernimont.com/index.html
They make custom fenders but I'm not certain if they make one for your application.
Old Mar 4, 2006 | 08:48 AM
Gummiente's Avatar
Gummiente
ORIGINAL: DGlide04
They don't fit now that the front forks have been enlarged to 49mm and the mount points have been changed. I've been looking all over for a longer front fender for my '06 FXDI, but haven't had any luck yet. The Dennis Kirk catalogue lists one in a ducktail style that says it will fit an '06, but that same fender is shown in the J&P Cycles book and they say it only fits up to '05.
Old Mar 4, 2006 | 11:16 AM
intruder400ex's Avatar
intruder400ex
You will have to paint it any way so you can easily fapricate it to fit, Just cut off the mounting plates from the original fender and weld it on the new one. If you wait untill next year there will probably be plenty to choose from.
Steve
Old Mar 4, 2006 | 11:51 AM
Gummiente's Avatar
Gummiente
ORIGINAL: intruder400ex
That's what I was thinking of doing, but the only question is whether or not the larger diameter fork tubes will require the fender to be dimpled in order to fit between them. If that's the case, I'll just wait until next year. Fabricating/adapting the mount plates is no problem, I'm just not very good at bodywork.
Old Mar 4, 2006 | 11:59 AM
intruder400ex
Ya hear ya I cant do body work worth a ****, Lucky I have a few friends that are in the buissnes. I was figuring that who ever was to paint the fender would do the body work also. Thats due to the reason that I cant paint worth of **** either.
Damn what can I due?
steve
Old Mar 4, 2006 | 01:29 PM
traveler's Avatar
traveler
Measure the distance between them on your bike, then go to the dealer or someone nearby with an'05 and measure theirs, that should give you an idea of what will be involved. I went with an ABS plastic Arlen Ness cafe fender in the front. Not larger, just looks different.....(better)
joe
Justind
Aug 2, 2017 09:38 PM
Bo_Jangles
Aug 7, 2012 07:12 PM
kmealp
Dec 13, 2009 10:16 AM
low_n_slow
May 30, 2009 08:17 PM
rounder
Nov 5, 2008 05:00 PM
