ICM Error Code B1122
Old Jun 10, 2008 | 08:15 PM
DGlide04's Avatar
DGlide04
Default ICM Error Code B1122
I've searched for trouble codes, I know some have been posted but I can't seem to find them when you need them.&nbsp\\;\\\\\\; Short story, coming home last weekend, the red security system key light came on, but a check revealed no error codes.&nbsp\\;\\\\\\; Everything worked okay yesterday, no problems.&nbsp\\;\\\\\\; I go out tonight and my right turn signal won't work.&nbsp\\;\\\\\\; The running lamp (stock bullets) are on front and back, but no signal.&nbsp\\;\\\\\\; When the ignition is turned on, the left signal blinks 6 times and goes off.&nbsp\\;\\\\\\; Left side works fine, no right signal.
A check of the error codes shows the following:&nbsp\\;\\\\\\; S for the Ignition Control Module, indicates error 61122.&nbsp\\;\\\\\\; Can anyone tell me what the error code is?&nbsp\\;\\\\\\; I can't find it listed anywhere.]]
The PIA is that everything was working good and when I checked the bike out tonight getting ready to go to work tomorrow, I get the codes thrown at me.
The bike is a 2004 FXD, stock lights and wiring, starts and runs fine, just no R signal.
Thanks.
Old Jun 10, 2008 | 09:12 PM
Splatter's Avatar
Splatter
Default RE: ICM Error Code 61122
Any chance the 6 is a "b"? If so, then it's one of a set of codes that are all basically saying "turn signals don't flash" and more specifically "Right turn signal does not flash."
&nbsp\\;\\\\\\;
But I guess it's not giving you any news....
&nbsp\\;
Flasher module? If you haven't done anything to make a wire snap and the running light is OK, then it's all I can come up with.
Old Jun 10, 2008 | 09:20 PM
laytonj1's Avatar
laytonj1
Here's the codes. Yours is probably b1122
Jim
http://personal.linkline.com/cdesigns/Error%20Codes.pdf
Old Jun 11, 2008 | 07:50 AM
DGlide04's Avatar
DGlide04
ORIGINAL: laytonj1
Jim
Thanks, it is b1122 and that brings me to another question.&nbsp\\; If the error was thrown by a short somewhere, shouldn't the lights be out altogether?&nbsp\\; The running lights work fine so there is power to the sockets.&nbsp\\; Bulbs work well in the left sockets so it is not a bulb problem.&nbsp\\; If there is a short, I would guess it is in the power wire to the signal wire in the front light as the rear light has a single filament bulb.
Thanks for clearing up the error code mystery.
Old Jun 11, 2008 | 08:25 AM
dyna07custom's Avatar
dyna07custom
possibly the flasher module
Old Sep 20, 2010 | 12:30 AM
drakenkade's Avatar
drakenkade
Default check the simple things first!!!
Make sure you check the simple things first. I had a 2000 softail that had a similar problem it turned out to be a dirty bulb.
Later..............
Old Sep 20, 2010 | 09:14 AM
HATZO1's Avatar
HATZO1
I just had this code come up last week (b1122) found out that my left signal harness had come loose and I wore threw the wire.
Old Sep 22, 2010 | 08:25 PM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
I got this code when I pinched the tank console indicator lights wire bundle between the mounting stand-off and the console plate...
Nokkon Wud
Feb 26, 2018 10:18 AM
danl
Jul 15, 2011 09:16 AM
Rock4gzus
Jul 7, 2009 08:16 PM
DGlide04
Jun 11, 2008 06:33 PM
slugo
Jan 11, 2007 10:59 PM
