Screamin Eagle II
Old Jun 11, 2008 | 01:43 PM
shadowlord256's Avatar
shadowlord256
Stage IV
Default Screamin Eagle II
I have a 2008 Street Bob and a buddy just gave me a set of slip on Screamin Eagle II pipes off his 2006 Street Bob.&nbsp\\; The pipes are stamped with a message that they are not street legal.&nbsp\\; Does anyone know if these will work on my bike?&nbsp\\; Will I need any adjustments?&nbsp\\; Will they void my warranty?&nbsp\\; Thanks for you help.
Old Jun 11, 2008 | 01:48 PM
jrsmith_80's Avatar
jrsmith_80
Default RE: Screamin Eagle II
I am not sure about the waranty part but I put them on my 07 Lowrider and have not had any problems.&nbsp\\; Once you put them on make sure you ride your bike for a bit to let the ECM adjust to the new exhaust flow.&nbsp\\; I dont see why they wouldnt work on you bike.
Old Jun 11, 2008 | 02:00 PM
BluBob's Avatar
BluBob
There is no possible way to make those fit on your bike.&nbsp\\; And if you do, they will probably cause the engine to melt.&nbsp\\; You can ship those out to me for disposal, and all I will charge you is the postage.&nbsp\\; PM me for my address.
Old Jun 11, 2008 | 02:05 PM
BluBob's Avatar
BluBob
Just kidding.&nbsp\\; I bet they will work fine.
Old Jun 11, 2008 | 04:05 PM
bronk's Avatar
bronk
No they will not work fine if you just put them on. You need a fuel managment item(SERT&lt\\; DFO&lt\\; etc) Otherwise you run the risk of running way too lean and burning up your valves.
Old Jun 11, 2008 | 04:23 PM
Low_Wider's Avatar
Low_Wider
Bronk, afraid to disagree. So long as he stays with the stock A/C he should be OK. If he goes with a free flowing A/C then he needs to look for at least a Stage 1 download to the ECM, Nightride IEDs or some of the other fuel managment gizmos.
BTW, you should probably do the stage 1 download or the Nightrider IEDs anyway, you'll enjoy the improvement in the ridability.
Old Jun 11, 2008 | 04:33 PM
BluBob's Avatar
BluBob
Don't need fuel management until you go to a high flow air cleaner, but I agree\\; I would go with a high flow A/C and get the fuel management taken care of as well.&nbsp\\; Big difference in the snap of the bike!
Old Jun 11, 2008 | 07:09 PM
HDDyna2006's Avatar
HDDyna2006
Got me a pair of SE II on ebay for $46.00 shipped, after cleaning them with Shout and a toothbrush, they look inmaculate. what a deal I got. Only problem is that the rivet that holds baffle in place is little loose, thinking about using C washer to the outside of rivet to tight it. any other suggestions?&nbsp\\;
running IED with OEM air filter.
BTW I might sell my HD blunts on Sig picture if anybody is interested, drill out permanent baffles.
Old Jun 12, 2008 | 09:55 AM
Dawg Rider's Avatar
Dawg Rider
Only problem is that the rivet that holds baffle in place is little loose, thinking about using C washer to the outside of rivet to tight it. any other suggestions?&nbsp\\;\\\\\\;&nbsp\\;
&nbsp\\;
Drilling out the rivet and replacing with bolts/screws, nuts, and washers works better IYAM. Those rivets are forever working loose, and I hate rattles.
Old Jun 12, 2008 | 10:02 AM
JRK5892's Avatar
JRK5892
will work fine... they say that cause they have to put that on non OEM parts
