Cobra Headlight problem
Old Jun 17, 2008 | 01:48 AM
coliseum's Avatar
coliseum
Default Cobra Headlight problem
&nbsp\\;I got the Cobra Headlight from easternperformance and I got it installed at the dealer... they seem to have messed up by making the low beam high and high beam low...
Can i fix it myself?&nbsp\\; dealer is a bit far and the weather is frakin hot.&nbsp\\; I remember that there were only 3 wires,,,&nbsp\\; black yellow and red i think... which wires should i swap?
Thanks.
Old Jun 17, 2008 | 11:48 PM
coliseum's Avatar
coliseum
Default RE: Cobra Headlight problem
Noone knows?
Old Jun 18, 2008 | 03:17 AM
Rauzer's Avatar
Rauzer
The red and yellow are your HB/LB swap them and see. I cant remember which is which.
Old Jun 18, 2008 | 07:59 AM
Airborne350G's Avatar
Airborne350G
If I remember correctly yellow is the high beam....Can confirm this when I get home.
Old Jun 18, 2008 | 08:26 AM
OhioSkully's Avatar
OhioSkully
I cant remember for sure which one is which but if its wrong then all you need to do is switch the wires yes you can do it simple job open light up and switch the wires around and test it.
Old Jun 18, 2008 | 10:32 AM
ghanes1's Avatar
ghanes1
Stage II
I looked at the wiring diagram and it shows White as High Beam and Yellow for low.
Old Jun 18, 2008 | 03:01 PM
2007fxdc's Avatar
2007fxdc
All I know is yellow doesn't wire to yellow on the bike.&nbsp\\; You can swap them but how easy depends on how it was wired.&nbsp\\; I cut and spliced my wires outside the neck so they would be very easy to switch on my bike.
Stick_Drifter
EVO
Jul 18, 2013 06:17 AM
nathanw
Electrical/Lighting/Alarm
Jul 6, 2012 08:05 AM
hrnttwk
Jun 12, 2012 01:40 PM
Maidenas
Apr 5, 2011 04:17 AM
CSI
Sep 14, 2006 11:32 PM
