Gremlin Bell
Old Jun 20, 2008 | 04:18 PM
trip20's Avatar
trip20
Default RE: Gremlin Bell
There's a wire ring for the brake linkage under the right forward control mine hangs from there.
Old Jun 20, 2008 | 04:38 PM
kulu's Avatar
kulu
i put mine on the front axil on the right side
Old Jun 20, 2008 | 04:57 PM
Splatter's Avatar
Splatter
If you don't like it, the best place for it is in a dumpster. Just smile and say, yes, you put it on your bike and thanks for the kind thoughts. If she comes to see the bike, use the same story as above about it being stolen.
&nbsp\\;
&nbsp\\;
Old Jun 20, 2008 | 09:06 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
&nbsp\\;
&nbsp\\;Hung mine from the clutch cable as it crosses under the engine, that's a pretty low spot on the bike.
Old Jun 20, 2008 | 09:12 PM
Baeseman1's Avatar
Baeseman1
ORIGINAL: SciFiGuy
ORIGINAL: sbchero
ORIGINAL: Topspin
I have mine in a hole on the frame just below the fork neck and&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\; about a foot above the voltage regulator. Looks good there.
same spot here.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;
&nbsp\\;\\\\\\;
Yep that's where mine is located also.
&nbsp\\;
Bingo!!!
Old Jun 21, 2008 | 01:51 AM
PKellyMc's Avatar
PKellyMc
From: PacNW; Beacon of Conservatism in a Sea of Liberals.......AZ Snowbird; Just another Conservative
Hung it on the circlip for the brake pedal/rod pin.
dawroz
Electrical/Lighting/Alarm
Feb 28, 2017 06:35 PM
Vernal
Nov 30, 2015 07:29 AM
kpb46
Oct 25, 2012 05:41 PM
cruise_carter
Apr 2, 2011 07:44 PM
FLHX66
Jul 27, 2008 12:13 PM
