brake fluid leak
Old Jun 21, 2008 | 12:47 AM
low06's Avatar
low06
Default brake fluid leak
the other day i noticed a little pain bubbling up around the lid on my front brake fluid resevoir. a friend of mine has the same bike, '06 low rider, and he has the same issue. i began tightening the screws and noticed a rubber flange under the lid started to schmoosh out a bit so i backed off the screws a half turn and called it good. anyone else seen this? is there a better lid or flange available?
Old Jun 21, 2008 | 03:00 AM
jmpancoast's Avatar
jmpancoast
Default RE: brake fluid leak
There have been many posts about this issue.&nbsp\\; A lot of the master cylinder gaskets were replaced under warranty.&nbsp\\; Some may have been due to improper tightening of the screws.&nbsp\\;
&nbsp\\;
As you mentioned, the screws do not need to be buried tight into the m/c body.&nbsp\\; They should be just tight enough to allow the gasket to sit flush and sealed around all edges.
Old Jun 22, 2008 | 02:07 AM
low06's Avatar
low06
gotcha. thanks.
Old Jun 22, 2008 | 07:38 AM
RockyTopRider's Avatar
RockyTopRider
i had the same problem on my 06 flstc. hd shop wouldn't warranty the repair. i pulled mine off, wiped it down, looked for a problem and couldn't find one. replaced it and it quit leaking. i duno how??
Old Jun 22, 2008 | 07:59 AM
Ratbasturd's Avatar
Ratbasturd
My dealer took a look at mine that was all paint bubbled and said&nbsp\\;\\\\\\; "yep, that's covered by warranty" and they even let me swap the part.
fatboy slim
Apr 9, 2014 08:41 PM
oinker02
Mar 20, 2009 08:54 PM
mikeshog
Mar 22, 2008 04:27 PM
robjohnston
Dec 12, 2006 07:37 AM
Unibomber
Oct 17, 2005 10:40 AM
