Valve check
Old Jun 21, 2008 | 09:36 PM
Marto's Avatar
Marto
6th Gear
Default Valve check
Is there a way to check the valves for damage.&nbsp\\; I've been trying to adjust my adjustable pushrods and am afraid i may have over tightened them possibly causing the valve to be damaged...now i'm seeing blue smoke from the exhaust which worries me.&nbsp\\;
Old Jun 22, 2008 | 05:24 AM
Gaffy52's Avatar
Gaffy52
Default RE: Valve check
If you are seeing blue smoke then the likely hood is you have damaged or are on the way to damaging something because you are&nbsp\\;burning oil thus the blue smoke.&nbsp\\; Why are you burning, well could be a number of reasons - the valves aren't seating correctly, a valve stem oil seal is damaged or worst case you've damaged or burnt the valve seats.&nbsp\\; The only real way to be sure is to strip the head and take a look.&nbsp\\; Of course you could be real lucky and by adjusting them correctly the valves seat correctly and all will be fine.&nbsp\\; You should also check you haven't bent the push rods too.
AK83
Shovelhead
11
Jan 9, 2020 12:08 AM
brenwald
Aug 15, 2012 07:21 AM
mdanehart
May 19, 2010 01:01 AM
gussound
Shovelhead
Feb 22, 2010 12:38 PM
Reffixer
Exhaust System Topics
Jan 10, 2006 01:22 PM
