Ignition mod
Old Jun 22, 2008 | 09:43 AM
redheadfred's Avatar
redheadfred
Default Ignition mod
Everyone seems to be doing the ignition mod moving it to the console . Anyone tryed moving it to the top mount and moving the horn ? Im thinkin bout doing it , but wanted some feedback if anyone has done it . Also how do ya get into the wiring in the neck ? Thanx&nbsp\\;
Old Jun 22, 2008 | 02:03 PM
pappy43's Avatar
pappy43
Default RE: Ignition mod
....Very interesting..seems a logical place to put it...I would do that relocate myself.. Keeps us posted if you decide to do it.&nbsp\\; Good luck.
Old Jun 22, 2008 | 03:04 PM
Muddyape's Avatar
Muddyape
Ive been thinking about it...especially since I moved the horn behind the battery box last winter.
Old Jun 22, 2008 | 03:09 PM
redheadfred
Can ya send me some pics of the location of ur horn ? That was another thing I was going to ask , try to get some ideas on that as well . Thanx&nbsp\\;
Old Jun 22, 2008 | 03:17 PM
Muddyape's Avatar
Muddyape
There is a brass threaded insert in the back corner of the battery box, I just used a 1/2" by 1/2" L bracket and drilled a hole in each tab, secured it to the battery box then bolted the horn up. Be careful to not tighten the horn stud too much it will mute the sound of the horn. I used a rubber washer and loctite to let the horn "float" on the bracket, the wires keep the horn from rotating. No issues with heat from the head/exhaust either. Hope this helps.
[IMG]local://upfiles/40507/0BFD5787DBCC45FE946713BB5F033090.jpg[/IMG]
Old Jun 22, 2008 | 03:28 PM
redheadfred
sweet , thanx man&nbsp\\;
GCJohnny
Harley Davidson Videos
Jun 14, 2017 02:07 PM
farmer65
Dec 24, 2016 11:05 AM
RedrumSG
May 5, 2012 06:48 PM
saintslax11
Jan 30, 2011 01:46 PM
jerm138
Aug 26, 2008 08:48 AM
