Rock in my Engine
Old Jun 25, 2008 | 07:09 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Default RE: Rock in my Engine
ORIGINAL: crash1292
your all fkn nuts....I can shift into 6th at 45.....NO NOISE NO RATTLES..I can run it as low as 1500rpm in 6th without any noise.
its a stroker motor ffs designed for high torque and low rpm.....dont believe the harley bs about lugging it...its just about them saving there own *** so they dont have to replace your sub standard crank
&nbsp\\;
Gee if I remember correctly the guy who posted has a Harley Davidson motor. Please do correct me if I'm wrong.
Old Jun 25, 2008 | 08:04 PM
domenicp7's Avatar
domenicp7
Keep the rpms up.&nbsp\\; I run 6th over seventy mph.
Old Jun 25, 2008 | 08:20 PM
h9ll's Avatar
h9ll
Lugging the engine period.&nbsp\\; You said "give it some gas"...which makes no sense especially if you are in 6th since that is strictly a cruising gear - need to get up and go - drop it into 5th.&nbsp\\; 6th is for cruising...
Old Jun 25, 2008 | 08:29 PM
h9ll's Avatar
h9ll
One more thing, RPM's aren't gonna mean squat to a new owner on a bobber - no tach.&nbsp\\; With that said its seat of the pants and a read of the manual.&nbsp\\; If it sounds like a rock in the engine or trashcan gettin' kicked around then its a pretty good bet you are in a gear to high for the low speed your runnin'.&nbsp\\; 70+ before hitting 6th is about right...if cruising.&nbsp\\; Otherwise if you are gunnin' for triple digits and/or top speed keep it in 5th. &nbsp\\;
Old Jun 25, 2008 | 09:25 PM
psmith007's Avatar
psmith007
It happens while I’m in fourth as well.&nbsp\\; In regards to lugging the engine and using my tach, I do not have a tach, and I’m pretty sure my RPM are high enough.&nbsp\\;
Old Jun 25, 2008 | 09:44 PM
the blob's Avatar
the blob
down shift i get the rocks hitting my fender sound as well if i whack it open in sixth and im only doing 55- 60 mph.
Old Jun 25, 2008 | 10:32 PM
KBFXDLI's Avatar
KBFXDLI
No way can I run my bike in 6th gear under 60mph. I have a tach. rpms will fall below 2000 every time.
Old Jun 25, 2008 | 11:01 PM
Dyna_Soar's Avatar
Dyna_Soar
ORIGINAL: domenicp7
Keep the rpms up.&nbsp\\;\\\\\\; I run 6th over seventy mph.
&nbsp\\;
On a flat piece of road, I can safely do 45mph in 6th with any lugging. I would never suddenly open the throttle or anything, but the motor runs perfectly fine with a light load. If I needed to accelerate or go uphill, I would downshift first.
&nbsp\\;
I do miss the tach that was on my Sportster though. Has anyone put a tach on their Bobber? Where did you mount it?
Old Jun 25, 2008 | 11:03 PM
wescoot2's Avatar
wescoot2
ORIGINAL: psmith007
It happens while I’m in fourth as well.&nbsp\\;\\\\\\; In regards to lugging the engine and using my tach, I do not have a tach, and I’m pretty sure my RPM are high enough.&nbsp\\;\\\\\\;
&nbsp\\;
Since you don't have a tach, give us an idea what speed your at in 4th, or 5th gear when you try and twist the wick, and get that noise.
&nbsp\\;
Ed
Old Jun 26, 2008 | 04:30 AM
domenicp7's Avatar
domenicp7
ORIGINAL: Dyna_Soar
ORIGINAL: domenicp7
Keep the rpms up.&nbsp\\;\\\\\\;\\\\\\\\\\\\\\; I run 6th over seventy mph.
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;
I find at that speed you are going to lug the motor.&nbsp\\; There is no way I could bump it into 6th doing 45mph flat maybe down hill with no throttle.&nbsp\\;
