Rock in my Engine
Old Jun 25, 2008 | 12:56 PM
psmith007's Avatar
psmith007
Default Rock in my Engine
I have a 2008 street bob.&nbsp\\; I have about 1700 miles on it so far.&nbsp\\; My question to you is this—when I put the bike in 5th or 6th gear and give it the gas, sometimes it sounds like there are rocks in the engine banging around.&nbsp\\; This only happens when I pull the throttle back fast.&nbsp\\; Does anyone have an idea what this may be and if so should I have it looked at?
Old Jun 25, 2008 | 01:00 PM
hk_shooter's Avatar
hk_shooter
Default RE: Rock in my Engine
Could it be spark knock?
You running good gas in it?
Old Jun 25, 2008 | 01:14 PM
psmith007's Avatar
psmith007
Ya 92octane
Old Jun 25, 2008 | 01:52 PM
Cornhusker's Avatar
Cornhusker
Sounds like you might be shifting too soon and don't maintain necessary RPM's following the shift for hard acceleration.
Old Jun 25, 2008 | 01:53 PM
wescoot2's Avatar
wescoot2
Could you possibly be twisting the wick when your engine was already lagging....in other words, were you running at least 2000 RPM before you opened the throttle??&nbsp\\;
&nbsp\\;
Ed
Old Jun 25, 2008 | 03:37 PM
wrenchbendr's Avatar
wrenchbendr
yeah my fatbob sounds like that also when you roll on the throttle in sixth and the revs are a little low.&nbsp\\; seems to have gotten better with miles though.
Old Jun 25, 2008 | 03:39 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
You are lugging the engine. Not good for it. Get the revs up. I keep mine at 2300&gt\\;
Old Jun 25, 2008 | 06:20 PM
rayfinseats's Avatar
rayfinseats
Don't shift to 6th below 60 MPH. You're lugging it. Piston rattle is hard on motors.
Old Jun 25, 2008 | 06:32 PM
crash1292's Avatar
crash1292
your all fkn nuts....I can shift into 6th at 45.....NO NOISE NO RATTLES..I can run it as low as 1500rpm in 6th without any noise.
its a stroker motor ffs designed for high torque and low rpm.....dont believe the harley bs about lugging it...its just about them saving there own *** so they dont have to replace your sub standard crank
Old Jun 25, 2008 | 06:33 PM
Major Woodie's Avatar
Major Woodie
+1 on the shifting too soon. That's&nbsp\\; the problem.&nbsp\\; I wasn't used to the extra gears and learned that lesson too.&nbsp\\; Also as a couple other posts mentioned...never shift to 6th unless your doing at least 60 mph.&nbsp\\; Crusing at 65mph or higher works best for 6th from what I'm seeing.
