DOT4 to DOT5?
Old Jun 25, 2008 | 07:42 PM
SC-Longhair's Avatar
SC-Longhair
Default DOT4 to DOT5?
Anyone have a problem with the DOT4 brake fluid eating the front master cylinder cover/gasket?&nbsp\\; Anyone ever flush the DOT4 out and replace with DOT5?
Old Jun 25, 2008 | 09:33 PM
mud's Avatar
mud
Default RE: DOT4 to DOT5?
ORIGINAL: sclonghairbadboy
Anyone have a problem with the DOT4 brake fluid eating the front master cylinder cover/gasket?&nbsp\\;\\\\\\; Anyone ever flush the DOT4 out and replace with DOT5?
It is a known issue.
The dealership will replace the cover with the correct one
at no charge.
https://www.hdforums.com/m_2962954/tm.htm
mud
Old Jun 25, 2008 | 09:49 PM
SC-Longhair
Uh, nope.&nbsp\\; I was at the dealer today and they said they could replace the cover and gasket but it would be the exact same one.&nbsp\\; Chalked the problem up to DOT4 fluid 'eating' everything. &nbsp\\; &nbsp\\;
Old Jun 25, 2008 | 10:06 PM
TOMMAY's Avatar
TOMMAY
&nbsp\\;
They will replace the cover and even the master cylinder under warranty but won't swap the fluids. Go figger.
&nbsp\\;
Good Luck
&nbsp\\;
Tom
Old Jun 25, 2008 | 10:11 PM
SC-Longhair
I'll try to appeal to them using "warranty" extensively. &nbsp\\; I don't think they realized my bike was still under warranty when I spoke to them today.
Old Jun 25, 2008 | 10:51 PM
freebyrd's Avatar
freebyrd
so you should use dot 5 on an 07 streetbob?
Old Jun 25, 2008 | 10:59 PM
SC-Longhair
I'd check with either the service manual or your dealer about that.
Old Jun 25, 2008 | 11:08 PM
VenturaChop's Avatar
VenturaChop
read the top of the master&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\; it says what to put in it
Old Jun 26, 2008 | 05:42 AM
hdslam's Avatar
hdslam
Do Not switch to Dot 5.&nbsp\\; Dot 5 is used on 2004's, and is silicone based.&nbsp\\; Meaning, water will not permiate the liquid. However, it will still enter the brake system, but remains on top.&nbsp\\; You will also not get the firm feel with Dot 5, which you have w/ Dot 4.
Dot 5 is very expensive, and difficult to find in large bottles. I bought a gallon from Napa Auto Parts for my bikes.&nbsp\\; My 99 Softtail has stock brakes w/ Dot 4, and stops better.&nbsp\\; IMHO, firmer feel of lever.&nbsp\\;
Dot 5 has a squishy feel to the levers. You also have to be very careful as far as contaminents when servicing the brakes with Dot 5.&nbsp\\; I flushed my system several times before I could achieve a firm feel to the brakes.
Do a search, many blogs regarding the DOT question.&nbsp\\; The only plus to DOT 5, is it won't eat the paint on your bike.&nbsp\\; DOT 5 was used in racing because of the high resistance to heat discipation, so Harley jumped all over it, then realized it was not a good decision because of braking issues.
dchoran
Jul 12, 2016 10:08 PM
thejgw
Jun 20, 2008 03:53 PM
BLLYGOAT
Jun 13, 2008 03:31 PM
TOMMAY
Jun 11, 2008 07:31 AM
fonemann
Jun 7, 2008 09:45 AM
