dead speedo
Old Jul 7, 2008 | 11:05 AM
garyn's Avatar
garyn
3rd Gear
Default dead speedo
I have a 2002 fxdwg. I removed the console and made a piece for a cleaner look. I move the tach – auto meter 19306 and speedo – 19340 to a handle bar/bracket combo. The tach works great, the speedo worked for awhile. Now, most of the time, mileage/speed do not register. When I turn on the ignition I can switch between total mileage and trip mileage. If there are any trip miles, I can reset to zero. When I fire my bike up the needle sits. Any ideas?
Old Jul 7, 2008 | 11:13 AM
Exavier22003's Avatar
Exavier22003
Default RE: dead speedo
Not sure if its the same problem I had but I will give my two bits.
&nbsp\\;
I recently had my speedo go dead also and had to take it to the dealer. Diagnosis was a carcked soder point on the comperter board where the pulg from the speedo connected. Since mine is an 08 it was still under warranty they covered cost. Also I had friends talk about others that had the same problem and found that it was ony a pin in the plug that had worked loose. May want to check on that.
Best of luck to you in fixing it.
3bc
Mar 7, 2015 08:25 PM
tencrore
Oct 10, 2014 02:59 AM
rebel23232
Aug 27, 2010 12:54 PM
garyn
Jul 7, 2008 11:18 AM
ioncat14
Jun 29, 2008 08:10 PM
