Project mini-front fender...
Old Jul 9, 2008 | 03:16 PM
bosken's Avatar
bosken
Default Project mini-front fender...
Removed the bracket from the front fender, going to cut it down as the badly done photoshopped picture below...
&nbsp\\;\\\\\\;
Any ideas on what to use for reassemble the bracket to the fender? Bolts will touch the tire....&nbsp\\;\\\\\\; Bolts from inside out will not look so nice.
[IMG]local://upfiles/38367/09501B9785B34C8BA0A73A444D5F3DF0.jpg[/IMG]
[IMG]local://upfiles/38367/0D382B144B9B4A6A9D55A592974A507C.jpg[/IMG]
[IMG]local://upfiles/38367/1254124A2A8347A6A748BE49BEF2EA38.jpg[/IMG]
Old Jul 9, 2008 | 03:19 PM
Redbeard's Avatar
Redbeard
Default RE: Project mini-front fender...
Is welding an option?
Old Jul 9, 2008 | 03:27 PM
bosken's Avatar
bosken
Yes... it will probably look best, welding it from the inside. no holes or other stuff...
Just have to find someone who can weld it for me..
Old Jul 9, 2008 | 03:30 PM
wtf6316's Avatar
wtf6316
Find some one with a rivet gun maybe. Or weld it from underneath.
Old Jul 9, 2008 | 03:36 PM
HOGRIDA_06's Avatar
HOGRIDA_06
I think someone on here used JB Weld to put it back together.
Old Jul 9, 2008 | 03:40 PM
Dawg Rider's Avatar
Dawg Rider
&nbsp\\;
That was Special Ed.
Old Jul 9, 2008 | 03:43 PM
JRK5892's Avatar
JRK5892
just re drill and toss a few rivits in it... you may also want to look at going a bit shorter on the front and a bit longer on the back... just to keep the crap from flying up... i just did a fat bob conversion on my front fender, just did all of what your are doing (did not cut it shorter, just moved it back to wrap the tire more) but i still had to redrill and rivit it back up. let me know if i can help!
Old Jul 9, 2008 | 03:46 PM
SPECIAL ED's Avatar
SPECIAL ED
I used JB weld on mine and it's held up well for about a year now.I originally intended to drill some holes in it after it was set up and bolt it together but the JB Weld felt so solid I just put it back on and called it good.Before I JB welded it I did strip all the paint off the contacting surfaces, cleaned them with alcohol then applied liberal amounts of JB Weld.I'm pretty sure if it holds my full sized fender in place it could hold that mini real good.
Old Jul 9, 2008 | 03:54 PM
mud's Avatar
mud
ORIGINAL: bosken
Bolts will touch the tire.... Bolts from inside out will not look so nice.
weld it bosken.
mud.......
https://www.hdforums.com/fb.asp?m=3116540
Old Jul 9, 2008 | 04:03 PM
JRK5892's Avatar
JRK5892
that was the pic i was looking for! I LOVE THAT FENDER MUD!
