Tie Down questions
Old Jul 10, 2008 | 09:01 PM
2007fxdc's Avatar
2007fxdc
Default Tie Down questions
Looking for tips and techniques to tie my bike down in the back of my truck.&nbsp\\; I'm planning to load the bike straight in the center of the bed on a 3/4 inch sheet of plywood that will have a harbor freight locking wheel chock mounted to it at the front.&nbsp\\; I want to tie the bike down as if there is no chock.&nbsp\\; My questions are:
&nbsp\\;
What are the best points at the front and rear of the bike to attach the straps to?
&nbsp\\;
Do I really need padded straps or is that overkill?
&nbsp\\;
Do I haul the bike in gear or in neutral?&nbsp\\; If in gear, what gear is best?
Old Jul 10, 2008 | 09:07 PM
bberck's Avatar
bberck
Default RE: Tie Down questions
Haul it in neutral.
&nbsp\\;
I dont think you need padded straps but I would get the kind that puts the hook away from the bike.
&nbsp\\;
Old Jul 10, 2008 | 09:19 PM
Donny's Avatar
Donny
well, i had complete instructions typed out, but forum would'nt let me post.[:@]
Old Jul 10, 2008 | 09:23 PM
HDJaco's Avatar
HDJaco
Four straps in total
Two straps in the front / two straps in the rear
Strap on the right &amp\\; left side of the base of your handlebars - Make sure you do not strap over the cables or wires
Strap the rear on each side of the swing arm or at the base of the shocks
YES YOUR BIKE SHOULD BE IN 1ST GEAR!
Make sure you have a wide ramp that levels off at the top
Good luck!
Jay
Old Jul 10, 2008 | 09:33 PM
DoubleU's Avatar
DoubleU
2 in front, around the bottom of the trees.&nbsp\\; 2 in rear around the shocks, upper or lower.&nbsp\\; I leave mine in N.
&nbsp\\;
Dub
Old Jul 10, 2008 | 09:37 PM
2007fxdc's Avatar
2007fxdc
ORIGINAL: Donny
&nbsp\\;
I hear ya Donny.&nbsp\\; I actually had to type my entire post twice because of the same problem.
&nbsp\\;
Okay guys, thanks for the responses.&nbsp\\; There seems to be some differences on the strap points.&nbsp\\; Maybe it doesn't matter that much.&nbsp\\; But, I forgot to ask how much, if any, I should compress the front end when I strap it down - don't want to blow a seal.
Old Jul 10, 2008 | 09:41 PM
mud's Avatar
mud
ORIGINAL: 2007fxdc
Looking for tips and techniques to tie my bike down in the back of my truck.&nbsp\\;\\\\\\; I'm planning to load the bike straight in the center of the bed on a 3/4 inch sheet of plywood that will have a harbor freight locking wheel chock mounted to it at the front.&nbsp\\;\\\\\\; I want to tie the bike down as if there is no chock.&nbsp\\;\\\\\\; My questions are:
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
Do I haul the bike in gear or in neutral?&nbsp\\;\\\\\\; If in gear, what gear is best?
Did you do a search??
asked and answered many times.
mud
Old Jul 10, 2008 | 09:50 PM
2007fxdc's Avatar
2007fxdc
ORIGINAL: mudpuddle
mud
&nbsp\\;
Yeh, actually I did.&nbsp\\; I guess I can't think of good words or phrases to search on.&nbsp\\; Found some stuff just now using google though.&nbsp\\; I'm still curious about how much I should compress the front and/or rear end though - anyone?
Old Jul 10, 2008 | 09:56 PM
mud's Avatar
mud
ORIGINAL: 2007fxdc
ORIGINAL: mudpuddle
mud
&nbsp\\;\\\\\\;
Yeh, actually I did.&nbsp\\;\\\\\\; I guess I can't think of good words or phrases to search on.&nbsp\\;\\\\\\; Found some stuff just now using google though.&nbsp\\;\\\\\\; I'm still curious about how much I should compress the front and/or rear end though - anyone?
Try the words trailer straps
Old Jul 11, 2008 | 12:44 AM
RAWHIDE07's Avatar
RAWHIDE07
Heres how I do it,I don't attach to the bars and I only compress the forks about halfway.
[IMG]local://upfiles/50648/9175EE0C5E544F86B9739B68C3550881.jpg[/IMG]
