Clutch adjustment
Old Jul 11, 2008 | 08:01 AM
davidc's Avatar
davidc
Default Clutch adjustment
I took today off to do some maint on the bike. I was adjusting the clutch as per the instructions in the service manual. My questions is before I close everthing up there seem to be excessive drag when I try to move the bike with it in gear and the clutch pulled in. Is it too tight? I turned the screw in then out 3/4 of a turn the manual said 1/2 to 1 turn so I split the differance.
Old Jul 11, 2008 | 08:07 AM
smitty901's Avatar
smitty901
Default RE: Clutch adjustment
go here watch both videos do just as they show and you will have no problems
&nbsp\\;
http://www.hdtalking.com/transmissio...ent_video.html
Old Jul 11, 2008 | 08:27 AM
BluBob's Avatar
BluBob
If the bike is not running it will give some resistance when in gear with the clutch pulled.&nbsp\\; I know mine does.
Old Jul 11, 2008 | 09:27 AM
Slipstrm's Avatar
Slipstrm
ORIGINAL: BluBob
If the bike is not running it will give some resistance when in gear with the clutch pulled.&nbsp\\;\\\\\\; I know mine does.
&nbsp\\;
Mine&nbsp\\;has&nbsp\\;some resistance when in gear and not running too.
Old Jul 11, 2008 | 10:14 AM
bobad24's Avatar
bobad24
I adjust mine until I can pull the cable from the lever bracket and just squeeze a quarter in the gap. Always works perfect.
Old Jul 11, 2008 | 10:31 AM
davidc's Avatar
davidc
Thanks for replys, I had it right there is some resistance when the motor is not running. When I started it seems to be fine.
bran48
Mar 16, 2014 10:40 PM
mrthinkshesfunny
Jan 18, 2010 02:11 AM
1986FXST
EVO
Jul 5, 2008 05:32 PM
Tltrump
Jul 1, 2008 10:37 PM
dbcoooper
Jun 20, 2008 11:49 PM
