Wiring in frame
Old Jul 12, 2008 | 11:36 AM
Frankster69's Avatar
Frankster69
Default Wiring in frame
Is there a easy way to put wires back inside frame&nbsp\\; thanks
Old Jul 12, 2008 | 11:37 AM
Frankster69
Default RE: Wiring in frame
Came uplugged when relocating turn signals pulled it out to plug it back in
Old Jul 12, 2008 | 11:39 AM
Frankster69
now wires dont want to go back into frame
Old Jul 12, 2008 | 11:44 AM
mud's Avatar
mud
ORIGINAL: Frankster69
Is there a easy way to put wires back inside frame&nbsp\\;\\\\\\; thanks
In the front?? under the tank??
What kinda bike is it?? year??
mud
Old Jul 12, 2008 | 11:53 AM
glideridemike's Avatar
glideridemike
Mud is right.&nbsp\\; On my '03 WG when I replaced my bars I had to pull them out slowly, carefully, and&nbsp\\;&nbsp\\;patiently, take the sockets apart, and when I stuffed them back into the backbone just behind the head of the frame it&nbsp\\;was slowly, carefully and patiently, and its nothing but a pita but its the right way to do it.&nbsp\\;&nbsp\\; If you had to pulle the harness up to the front from the back of the frame its much the same although it will take a helper at the other end.
Old Jul 12, 2008 | 11:56 AM
roofer's Avatar
roofer
What I did is take out the battery and move away as many wires as possible don't disconnect anything and reach down with a set of long curved neeldle nose pliers and gently pull the wire loom and at the same time push the loom at the neck hope this helps you out
Old Jul 12, 2008 | 12:21 PM
Frankster69
Seams like hole in frame got smaller lol thanks guys
Old Jul 12, 2008 | 12:22 PM
Frankster69
2002 Superglide
Old Jul 12, 2008 | 12:24 PM
Frankster69
If I try to post to many words it wont let me
Old Jul 12, 2008 | 12:27 PM
Frankster69
Ill feed them back slowly&nbsp\\; crazy setup
