2007 Dyna 6 wires to rear lighting...
whats what?
I know which are signals, got the brake ok and I'm guessing black is common grnd for sigs. which is run and what does the other hot do?
whats what?
No you don't need a resistor for just the LED tail light, with stock turn signals. That's what I have, and I have no resistor or (load balancer/equalizer)
Thank's Mud that's exactly what I was looking for!!
Got it all wired up, one problem. The LED cat eye tail light I'm using only has two wires Run and Brake the chassis acts as ground. do I wire both brake wires to the brake side. right now I only have one wired in and it works.
Yeah I know I need a manual, but fact is I don't have one. Maybe someday....
Is that a Fat Boy fender? Have you thought about nixing the lp mounted stop lamp and using a Run Stop Turn moudle to make the turn sig into running, directional and stop lamps?
