Oil Change Question
Old Jul 14, 2008 | 09:35 PM
mcdaniel52761's Avatar
mcdaniel52761
Default Oil Change Question
When changing the oil (and filter) on a 2005 Dyna Super Glide, what is the proper amount of oil to put in? I assume it's 2.5 from what I've read and that's what I put in. I checked it cold on the jiffy stand and it was just about up to the full hot mark. Then I went for a short ride to warm the engine up, pulled the dipstick and it was about half way up the full hot mark...this was also done resting on the stand. I thought it would have went the other way....reading higher when hot (or at least warm). Thanks,
&nbsp\\;
Mike
&nbsp\\;
Old Jul 14, 2008 | 09:43 PM
mud's Avatar
mud
Default RE: Oil Change Question
ORIGINAL: mcdaniel52761
&nbsp\\;\\\\\\;
Mike
&nbsp\\;\\\\\\;
2.5 should be about right Mike.
The dipstick will tell the actual correct level.
Went down in this case,
cause the oil filter absorbed some after startup.
mud
mcdaniel52761
Apr 22, 2012 02:20 PM
DukeofEarl
May 10, 2010 12:30 AM
ronster2
Oil Archive (no new posts)
Sep 24, 2009 09:46 AM
albanynyharleyrider
Jul 14, 2008 02:21 PM
RECON1
Apr 28, 2008 07:13 PM
