49mm front turn signal brackets.
Old Jul 16, 2008 | 11:18 AM
jarhead45's Avatar
jarhead45
Default 49mm front turn signal brackets.
and another thing .. who has ,, in stock those 49mm front turn signal locater brackets. I called J&amp\\;P and they are out and have no idea when they are coming in. Harley brackets are ugly as sin (sorry guys) sticking way out there. anyone else make them. The Kuri ones look good but I dont think they are going to fit right. Wish I was a machinist, problem solved then.
Old Jul 16, 2008 | 11:24 AM
2007fxdc's Avatar
2007fxdc
Default RE: 49mm front turn signal brackets.
The Kury ones will fit but you will have to replace the bolts with fine threads.
Old Jul 16, 2008 | 11:55 AM
l.ray's Avatar
l.ray
+1 on that machine threads l.ray[sm=biker.gif]
Old Jul 16, 2008 | 11:59 AM
l.ray's Avatar
l.ray
Sorry machine thread is wrong= MM l.ray
Old Jul 16, 2008 | 03:06 PM
jmpancoast's Avatar
jmpancoast
As an alternative (cheap and looks good), consider using your ball mount recepticle which currently is used to mount the signal on the left side of your bars.&nbsp\\; You can pick up a second one at your dealer.&nbsp\\; Drill the hole to 3/8" and you can mount it to the lower tree using the pinch bolts.
&nbsp\\;
Details are available in the Mud's sticky located at the top of this page.
&nbsp\\;
Here's a pic:
&nbsp\\;
tadavis
May 1, 2016 09:45 PM
o/d
Softail Parts
Jan 20, 2014 10:11 AM
Radalack17
Jan 29, 2009 12:43 PM
flash1034
Apr 20, 2008 11:10 PM
cajun883custom
Mar 18, 2007 12:40 AM
