Cams worth it w/out head work?
Old Jul 17, 2008 | 09:29 AM
Dawg Rider's Avatar
Dawg Rider
Default Cams worth it w/out head work?
An indy wrench I know says that a cam change is not worth the trouble unless you also do head/cylinder work (mainly due to valve limitations). Opinions?
Old Jul 17, 2008 | 09:38 AM
wescoot2's Avatar
wescoot2
Default RE: Cams worth it w/out head work?
I had new cams did it mainly to get rid of the chain driven, as I went to gear driven.&nbsp\\; Yes, I did get to feel the difference in the seat of my pants.&nbsp\\; Since the scoot has almost 68K miles, I will be doing the top end over the winter, and getting headwork done, which should really show what new cams can do.
&nbsp\\;
Respects,
Ed
Old Jul 17, 2008 | 09:39 AM
Pooh AKA Bear's Avatar
Pooh AKA Bear
Find another indy! I installed cams with no headwork, no valve work and no adj pushrods. Was it worth it? You bet! Just don't go with extreme cams and you will be pleased and still have the durability and reliability of before but with a smile on your face! Just my 2 cents![sm=biker2.gif]
Old Jul 17, 2008 | 09:59 AM
jsbridgew's Avatar
jsbridgew
what these guys said... you don't need to do headwork.... just make sure you don't get too radical a cam, and you'll be fine.... i have HQ TC-500s, and no head work ....a HUGE difference in performance.... i intend on doing headwork over the summer, however
Old Jul 17, 2008 | 10:10 AM
Dawg Rider's Avatar
Dawg Rider
I had new cams did it mainly to get rid of the chain driven, as I went to gear driven.&nbsp\\;\\\\\\; Yes, I did get to feel the difference in the seat of my pants.&nbsp\\;\\\\\\; Since the scoot has almost 68K miles, I will be doing the top end over the winter, and getting headwork done, which should really show what new cams can do.
&nbsp\\;
I'm thinking along the same lines but wondering if I should wait and do it all at once. Any engine noise difference?
Old Jul 17, 2008 | 10:13 AM
Dawg Rider's Avatar
Dawg Rider
Anybody familiar with the Andrews 21G or 26G in an otherwise stock 88?
Old Jul 17, 2008 | 10:16 AM
JBaker421's Avatar
JBaker421
Big Kahuna HDF Member
Head work not needed unless you use higher rpm.
Old Jul 17, 2008 | 10:17 AM
JBaker421's Avatar
JBaker421
Cant post. S&amp\\;S 510 gears drives give BIG improvement without head work.
JBaker421's Avatar
JBaker421
Diff in sound, yes nice lope at idle with 510s but pulls hard in normal driving range.
Old Jul 17, 2008 | 10:18 AM
JBaker421's Avatar
JBaker421
Head work needed only for radical cam which then needs high rpms to work right.
