Slip on installation
Old Jul 20, 2008 | 12:56 AM
InkTheFlesh's Avatar
InkTheFlesh
6th Gear
Default Slip on installation
Can someone pooint me in the right direction for instructions on how to install Cycle Shack Slip Ons for an '08 Street Bob? Thanks in advance!
Old Jul 20, 2008 | 01:08 AM
ratpack enforcer's Avatar
ratpack enforcer
Default RE: Slip on installation
easy take factory off SLIP ON&nbsp\\; new ones tighten clamp's and there you go easy as 123
Old Jul 20, 2008 | 01:25 AM
BluBob's Avatar
BluBob
Beware the heat shields, they will scratch the new ones coming on if you are not careful.
Old Jul 20, 2008 | 01:27 AM
BluBob's Avatar
BluBob
Remove the mounting bracket before you twist the olds ones off. Watch the shields again when new ones go on. Line up the right rotation, torque clamps to 45-60 ft-lbs, mount the bracket.
Old Jul 20, 2008 | 07:49 AM
sargek's Avatar
sargek
The book says the muffler clamps must only used once, but I've had good luck reusing them. The torque BluBob mentioned is very important. It may seem excessive for a muffler clamp, but the clamps are the only thing holding the mufflers on. If you don't torque them to specs, your slipons can slipoff...
Old Jul 20, 2008 | 07:53 AM
maddghost's Avatar
maddghost
And I've heard to be very careful to wipe any fingr prints off before starting the engine&nbsp\\;with the new muffs
Old Jul 20, 2008 | 08:12 AM
SciFiGuy's Avatar
SciFiGuy
A little WD-40 will help with the removal of the stock mufflers.
hdoilcan
Apr 26, 2014 07:19 PM
1NewHDGuy
Apr 12, 2009 07:04 PM
Tarponrod
Exhaust System Topics
Mar 19, 2009 12:39 PM
Fupl18
Jan 12, 2009 07:55 AM
Hutson
Apr 11, 2008 07:11 AM
