Thump !
Old Jul 21, 2008 | 07:32 AM
wescoot2's Avatar
wescoot2
Default Thump !
Riding yesterday, after going over potholes, I'm getting a metal to metal feel transmitted thru my frame, any ideas?
&nbsp\\;
Thanks,
Ed
Old Jul 21, 2008 | 08:21 AM
jmpancoast's Avatar
jmpancoast
Default RE: Thump !
The simplest thing to check and fix is the jiffy stand bumper on the frame.&nbsp\\; It is common for this to hit something and rotate out of its intended position.&nbsp\\; Kit a sharp bump and the jiffy stand slaps the frame.
&nbsp\\;
Also, check your fuel tank and make sure the mounting bolts are tight.
&nbsp\\;
If you feel the jolt in the bars, you may have the loose steering head bearings.&nbsp\\; Not a complicated fix.&nbsp\\;&nbsp\\;There are several posts on here about the remedy for this.
Old Jul 21, 2008 | 08:53 AM
wescoot2's Avatar
wescoot2
Default RE: Thump !
I'm feeling it down in my highway pegs, I'm thinking I broke a motor mount.
Old Jul 21, 2008 | 10:25 AM
dyna07custom's Avatar
dyna07custom
Default RE: Thump !
front or upper motor mount could be loose not broke or could be the rubber has detoriated
Old Jul 21, 2008 | 10:56 AM
morepowr's Avatar
morepowr
Default RE: Thump !
another vote for gas tank loose.
Old Jul 21, 2008 | 11:08 AM
wescoot2's Avatar
wescoot2
Default RE: Thump !
Gas tank is tight, will check motor mounts later today.&nbsp\\; Can't complain they held out 68K miles.
&nbsp\\;
Thanks,
Ed
Hardly Dangerous
Aug 1, 2008 10:13 PM
daytonasteve
Jul 7, 2008 01:47 PM
Tn.Heritage
Jun 28, 2008 09:38 PM
DamifIknow
Jun 22, 2008 08:54 AM
daharleyrdr
Jun 17, 2008 09:40 AM
