BIG BORE ??
Old Jul 29, 2008 | 02:24 PM
MAX EVO's Avatar
MAX EVO
Default BIG BORE ??
What is the most reliable and cost effective kit to buy?The 103 or other kit options.I heard you should weld the fly wheel regardless.I am looking for good torque and reliabilty. thx This would be for an 08 Bob
Old Jul 29, 2008 | 02:29 PM
Bluesssman's Avatar
Bluesssman
Default RE: BIG BORE ??
You might want to look at having your heads reworked or replaced. You will make more power with that modification rather than just an increase in size. Hope this helps...
Old Jul 29, 2008 | 04:27 PM
dyna rider's Avatar
dyna rider
I'm just curious so excuse my ignorance, but what does welding the flywheels do for you? Why would you split the cases and not stroke it ?
Old Jul 29, 2008 | 05:31 PM
Cornhusker's Avatar
Cornhusker
I didn't go for any kit.&nbsp\\; Just had the cylinders bored and installed pistons and 211 cams.&nbsp\\; 101 ftlbs Torque and 94 HP.&nbsp\\; Good enough for a baby build.&nbsp\\; Runs as strong as I want it to for now.
&nbsp\\;
ORIGINAL: MAX EVO
MAX EVO's Avatar
MAX EVO
Not sure either, I read here on the fourm that when you hot rod the 96" the fly wheel can malfunction under stress and apparently some Indys suggest welding it for extra strength.
Old Jul 29, 2008 | 07:42 PM
chad peterson's Avatar
chad peterson
Welding stops the flywheels from scisoring and getting too much run out which won't allow gear driven cams, which is what I understand when mine was welded.&nbsp\\; As the 08 is already stroked all you would have to worry about is the scisoring, if you plan on beating it up!
jmb79
Nov 15, 2013 10:21 AM
aggiejason
May 19, 2013 07:50 AM
FL-kruzen
Oct 6, 2012 05:06 PM
DRAGO'S BIKE WORKS
Vendor For Sale Classifieds
Jan 14, 2011 06:29 AM
toyrider
Nov 19, 2006 02:38 PM
