95 Big Bore or 103 Big Bore (which one)
Old Oct 29, 2006 | 04:05 PM
toyrider's Avatar
toyrider
Default 95 Big Bore or 103 Big Bore (which one)
Thinking about doing some motor work done over the winter to my 05 Wide Glide. I am having a hard time on which way to go here. Just wanted to find out some difference of opinions.
Thanks
Old Oct 29, 2006 | 06:27 PM
DGlide04's Avatar
DGlide04
Default RE: 95 Big Bore or 103 Big Bore (which one)
If my ever faulty memory doesn't fail me, on a stock TC 88, the 95" is a total top end build, a 103" is a stroker that will involved the lower end modifications. You can still get a huge performance gain which may be a little more reliable in the long run than a stroker for a very reasonable cost. It's your choice.
Old Oct 29, 2006 | 06:34 PM
toyrider's Avatar
toyrider
DGlide94,
For reliability the 103 may be in question somewhat ???
Old Oct 29, 2006 | 07:00 PM
redheadfred's Avatar
redheadfred
check out the edelbrock site . they have a 95' that has a hell of alot more power than a SE kit . Their kit makes between 105 - 110 on the torq and 105 - 110 hp . Thinking about doing this kit myself . Check it out and compare it to a HD kit and let me know what ya think
Old Oct 29, 2006 | 09:25 PM
DenimStreet's Avatar
DenimStreet
I dont know about the 103 but look below at what I did to my Bob. It performs unbelievably! It is really more than I need (not that it has ever been about need) . Truthfully, it is actually difficult to ride slowly. 1/4 inch turn on the throttle and I am going 60 (no lie). I am thrilled with this upgrade and I leave all of my friends in the dust no matter what they ride. They are all amazed. I have the compression release heads to relieve the pressure and save me problems in the future.
Good luck!
Old Oct 29, 2006 | 09:32 PM
XXXRacing's Avatar
XXXRacing
First off, sweet ride. 2nd, I'd look into the 98" kit from GMR on here. With all of the work, it makes around 100/100 around what a 103 would make. I was planning on doing this winter but bonus was weak, so it'll have to be put off until next year.
Old Oct 29, 2006 | 09:43 PM
103FLHX's Avatar
103FLHX
Its not just cubes. Gotta think if you are going to go further. Gotta sort out your budget & want your expectations are.
A P&P 95 will out perform a straight 103.
[sm=icon_guiness.gif]
Old Oct 29, 2006 | 09:51 PM
redheadfred
what are some of the prices on these kits you guys are talking about ?
Old Oct 29, 2006 | 09:58 PM
DenimStreet
To tell you honestly, I don't remember. I think I blanked it out of my mind! I'm pretty sure, off the top of my head that my engine upgrades were close to $3,500 and the V&H pipes, with labor were around $1,400. So I think I topped 5K or $5, 500. (ouch) But......I wanted it!
ORIGINAL: redheadfred
Old Oct 29, 2006 | 11:09 PM
toyrider's Avatar
toyrider
I looked at the Edelbrock site and that looked very impressive.
The local HD Dealer said that the 95 upgrade with the cams would be around $3200 labor included. I was then thinking of going with the diamond cut heads for an additional $600.
HD= Hundreds of Dollars......but they are fun to ride
