Help for father in law
Old Aug 4, 2008 | 01:51 PM
beendad's Avatar
beendad
Default Help for father in law
FXDB on this forum needs some help with a rear end shimmy on his 07 street bob. Not constant, worse when lugging and always bad when turning. Any suggestions?
Old Aug 4, 2008 | 02:00 PM
dyna07custom's Avatar
dyna07custom
Default RE: Help for father in law
rear tire, rear wheel bearing, is belt adjusted correctly and wheel aligned&nbsp\\;&nbsp\\;
Old Aug 4, 2008 | 02:05 PM
beendad's Avatar
beendad
Belt is adjusted to spec as per his repair manual. How can you tell if tire is or bearing are bad? Bike only has 6 or so thousand miles on it and tire is in great shape tread wise. This all started after his 5000 mile service, which he did himself and which included the belt adjustment.
Old Aug 4, 2008 | 02:15 PM
glide05's Avatar
glide05
ORIGINAL: beendad
Then I would think the first thing is do the adjustment again - starting at step 1.
perhaps the 2 sides are not evenly adjusted?
Old Aug 4, 2008 | 03:06 PM
paul s's Avatar
paul s
Check torque on swingarm.&nbsp\\;
Old Aug 4, 2008 | 03:47 PM
96 Wide Glide's Avatar
96 Wide Glide
Put bike on lift, grab rear wheel and see if you can wiggle it. If you can, possible wheel bearing.
Old Aug 4, 2008 | 03:57 PM
fiend138's Avatar
fiend138
ORIGINAL: 96 Wide Glide
&nbsp\\;
Loose spokes?&nbsp\\; Tap them with a wrench and if they thud instead of a ring sound they are not tight.&nbsp\\;
Old Aug 5, 2008 | 11:44 AM
dyna07custom
ORIGINAL: glide05
ORIGINAL: beendad
+1 bet wheel is not aligned
Old Aug 5, 2008 | 11:58 AM
JRK5892's Avatar
JRK5892
sounds like a flat spot in a wheel bearing to me!
Old Aug 5, 2008 | 12:15 PM
beendad's Avatar
beendad
More info. The wheel was adjusted using the small allen looking tool for measuring the distance from the small hole in the swing arm and the two sides are spot on, however when you look at the axle nuts you can see that the right leg side appears to be farther forward in the actual axle hole than the left, almost the axle holes do not line up or the small holes in the swing arms arent matched up.
