Bike WON'T downshift!!!...Help!!!
Old Aug 7, 2008 | 12:10 PM
devils haircut's Avatar
devils haircut
Default Bike WON'T downshift!!!...Help!!!
Bike wont downshift while going above 15mph. I had to take a right turn in fifth gear last night. It has been sticking for a while, but last night it completely locked up. I have to stomp the living $h!t out of the shift lever to get it to budge, and that's when it wants to move at all. I already disassymbled the forward control to clean inspect and lube. That leads me to believe that the problem is inside the bike. WTF???!!!
Old Aug 7, 2008 | 12:16 PM
JRK5892's Avatar
JRK5892
check the shift arm, back behind the primary where the linkage is... i have had a rock hop up and get stuck up in there and keep the bike from doing the same.
Old Aug 7, 2008 | 12:21 PM
devils haircut
I'm gonna go check right now. Thanks.
Old Aug 7, 2008 | 12:26 PM
JRK5892's Avatar
JRK5892
let me know i will be on all day... i am at work with the site shrunk down... ill help ya figure it out
Old Aug 7, 2008 | 12:34 PM
dyna07custom's Avatar
dyna07custom
whose forwards? was shift lever removed?
Old Aug 7, 2008 | 12:40 PM
devils haircut
Found it! The old lever from the mids fell back and bound up with the aft lever from the forwards. (Does that make sense the way I explained it?) That is why I could upshift, but every time I up shifted... the old mid control lever would wedge further back. I'm not sure what to do about it just yet, but I think I will saftey wire it tonight at work.
Old Aug 7, 2008 | 12:43 PM
JRK5892's Avatar
JRK5892
ha ha ha told ya brother! had a rock in mine! usually if the bike will not shift that is why. glad you found it! ride safe man... ooh ya did oyu see the chrome kit that Bberk installed! looks awesome!
https://www.hdforums.com/forum/dyna-glide-models/263282-chrome-package-installed.html
Old Aug 7, 2008 | 12:48 PM
devils haircut
edit for crappy diagram attempt to explain... software "corrects" the way I typed it out to explain.
Old Aug 7, 2008 | 12:51 PM
JerseyDevil's Avatar
JerseyDevil
Haircut, I was going to suggest the same as Joe and take a look. Same thing happened to me where the old lever dropped down and stopped her from downshifting, kinda sucks when your in 6th and stuck on the highway. Easy fix though. This was with the Kury forwards.
Old Aug 7, 2008 | 12:56 PM
JRK5892's Avatar
JRK5892
take a picture of what you got going on man... maybe we can figure something out so this will never be an issue again... do you still have the little peg deal stickin out of the primary? not to sure what your talking about with the "old lever"
