What size apes will replace stock without changing cables?
Old Aug 7, 2008 | 06:04 PM
Streetbobfighter's Avatar
Streetbobfighter
4th Gear
Default What size apes will replace stock without changing cables?
I have a 06 streetbob and want to go wider on the apes but i don't want to change the cables what bars will work? Thanks
Old Aug 7, 2008 | 11:02 PM
AdrianVall's Avatar
AdrianVall
A member here that goes by the name JRK5892 has 14 inch apes with 2.5" risers with stock cables. But I believe he had to bend his brake line a bit.
But anything around there I suppose would work. I've read that some people used the 12.5" chubbies with stock cables. Those look good!
Old Aug 8, 2008 | 01:46 AM
JRK5892's Avatar
JRK5892
let me know if you have ?s i have them... here is my set up, real easy to do just takes some re routing and a few bends to the brake line
Old Aug 8, 2008 | 09:50 AM
Cherry101's Avatar
Cherry101
Default Hey Joe
What brand of apes are those? I'm having a hard time finding a set that aren't too wide at the base.... Those look perfect.
Thanks
Old Aug 8, 2008 | 10:44 AM
JRK5892's Avatar
JRK5892
i am told they are from JP cycles... i did some work for my uncle, put on his beach bars and these where haning in his garage BRAND NEW! so i took em! i think he said he paid 75 for them... if that helps i can measure anything you need me to.... just let me knwo
Old Aug 8, 2008 | 11:58 AM
dubblist's Avatar
dubblist
I have 12" Gimps and didnt have to swap anything out. I also heard you cna fit 14" Gimps too
Darrin Palmer
Jun 1, 2012 06:13 PM
arrowslinger1980
Dec 14, 2010 12:40 PM
Trux
Feb 28, 2010 09:36 PM
EzStreet
Aug 11, 2009 08:35 PM
mojojones
Nov 1, 2008 12:07 PM
