Belt tension adjustment question
Old Aug 8, 2008 | 09:59 AM
easy4me's Avatar
easy4me
hounds, what measurement do they give in the 07 manual without rider?
Old Nov 2, 2008 | 09:21 PM
mr. lowrider's Avatar
mr. lowrider
4th Gear
Cool belt tension on 2003 dynalowrider
I have a 2003 fxdl dynalowrider. I have a couple of questions concerning the drive belt tension.
1. Is the tension set with a rider on the bike?
2.Is the adjustment done on the jiffy stand or lift?
Thanks for your help.
Old Nov 2, 2008 | 09:56 PM
mo-fo-joe's Avatar
mo-fo-joe
my service manual for 2008 dyna bikes states, with motorcycle on jiffy stand without rider or luggage, 5/16 to 3/8 deflection [10lbs of force ]
or with vehicle upright with rear wheel in the air, 1/2 in to 9/16 deflection [10lbs force ]... i did mine with my bike up on my J&S jack and set it at between 1/2 and 9/16 and the bike runs and feels great. hope this helps bro.
Old Nov 2, 2008 | 11:36 PM
benwiggin2's Avatar
benwiggin2
Originally Posted by jmpancoast
p.s. If you weigh 300+ and need a person to sit on your bike, I can send you my ex. Make sure to sterilize your seat after she gets her fat *** off.
Bwahhahahhahhhaaahahahahahhhahhahahaaha
Old Nov 3, 2008 | 07:30 AM
davidsdad's Avatar
davidsdad
My 2007 manual says that you should be on the bike when adjusting the belt and the bike should be on the ground..
Old Nov 3, 2008 | 08:01 AM
rounder's Avatar
rounder
every tech I talk to says run the belt a little looser than suggested. Strange that fror 08 the manual says no rider weight and same measurement? wonder if it is a mistake.
Old Nov 3, 2008 | 03:11 PM
rounder's Avatar
rounder
did a little tension experiment today... had the shocks off to install my strut covers. I lowered the bike down as if I was sitting on it. The tension appears to measure the same as if there was no weight on the bike. I tried a few locations and cannot figure out why one needs bodyweight on the bike to adjust the tension. The measurements all came out the same. Maybe its because I have 11" shocks and the swingarm is less than parallel to the ground. Perhaps once past parallel the axle does not get any further away from the pivot point causing the belt to tighten under load.
Gordon65
Oct 22, 2014 10:01 AM
freebyrd
Jun 22, 2009 12:27 PM
cdestuck
Sep 16, 2008 04:10 PM
JaboIam
Feb 18, 2008 08:11 PM
Hounds2
Sep 15, 2007 03:04 PM
