Installing my new v&h exhaust on my 07 FXDB this weekend. On the gaskets, I will have to remove the gaskets from the bike and replace them with new gaskets. Questions:
Will they come out easily?
What method should I use to remove them, I assume they are pressed in pretty tight?
Yeah, get the regular gaskets, not the Screamin' Eagle ones. The normal ones are thicker and tapered and are better sealing than the thing SE ones. Install them so the taper faces out.
Thanks,
jimd4au
Here's the tool I use
and the part #s Here is the # - 65324-83A
You will probably also want to pick up #65325-83A (retaining ring)
will come out easy with a small flatblade...just wedge around the perimeter till they come out...bigger issue the retaining rings...you do have retaining ring pliers... right...!!??
